yes they are TVS diode.... unplug the U ribbon first and test them in Diode mode
Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
2 and 5 they are connect together ,,, if you say so mean no one defect... !! strange for me... you may telling the wrong side by right and left.... lol.... the side which u disconnect and u have picture on the rest... this disconnected side must test esd diode on it as u have 3 on each sideComment
the 1/4 of the tv with the "no picture" note is the one that has no picture and also the side with the buffer board that I was testing the tvs diodes on. I tested the diodes on the opposite side of the tv and have the same results.Comment
then block CKV line on the U ribbon side which it was on yours hand... you have the pins NO of CKV printed on the boards... give tryComment
75 RU series 6 & 7 was build on buffer boards 4 ESD Diode E5 with 6 pins, this what i have under my hand before.. they were not defect but at time i block CKV 2, was no reboot. from this point i always work on MB before i missing at panel buffer boards... one time was R 100Ohn besom more than 120K .. other one one cap was absolute shorted 0
at the end i want to say... if with out any Jumpers on FB test points... by disconnecting U ribbon on ODD Panels size only if you got picture on the rest clear... invest yours time on MB if the ESD are fineComment
he have double LVDS not one style. if this true only with FB connected come U ribbon then for me 99% T-CON on boards. or its spi firmware RU some things was better than TU or NU or MU
BTW.... his issue reboot... if one LVDS disconnected an no more reboot but no picture this will never tell Panel issueLast edited by Diah; 01-31-2025, 04:26 PM.Comment
So if tvs diodes check ok and not getting too hot, check the other things on that board, I see some caps and a resistor.Comment
Thinking I recall a while ago there was a tvs diode problem even tho it checked ok with diode testing.Comment
Extra whats? Check those 3 caps and the resistor, don't really know what else it could be, seems like it can be one of the tvs diodes, a component on that driver board the panel itself or a problem on mainboard as Diah mentioned.Comment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by rui4892Good morning.
the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
