Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
  • joel warren
    • Jan 2025
    • 32
    No caps were testing bad, so I have no way of knowing which cap to remove.
    • nomoresonys
      • 12331
      • U.S.
      #62
      Originally posted by joel warren
      which one is the resistor that I should be checking?
      Right there by the tvs diodes, says R6 I believe, right by the DT5 printed there, no joy on the caps or resistor then just remove tvs diode and test tv, I would start with number one, remove test tv no change put it back and try the others same way, no harm will be done as long as done correctly and you don't damage anything during removal. (not much to lose at this point I suppose) See if any of the three gets hotter than the others, if one does then I would start with that one. Might be an easier way to do it but I don't know of any.
      • nomoresonys
        • 12331
        • U.S.
        #63
        Suppose it's a problem with the panel itself. Maybe one of those caps on that board is bad but just not shorted??
        • bohaboha
          • Nov 2012
          • 1044
          • sweden
          #64
          yes as you say look at the hot ones use alcohol or a candle to detect look at this https://www.youtube.com/watch?v=srccct1mDIU&t=856s
          • nomoresonys
            • 12331
            • U.S.
            #65
            +1, Indeed, that is great advice, I remember whenever I first saw the candle method, thinking what a great simple procedure that hardly anyone thinks of.
            • Diah
              • Feb 2013
              • 6614
              or use yolk, eggs with brush on parts the one get first solid white its the one.... hahahaha but i dont know if yolk, contain water LOL
              • nomoresonys
                • 12331
                • U.S.
                #67
                Hell why not, a little shouldn't hurt lol.
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                  09-07-2024, 05:50 AM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • rui4892
                  Samsung UE55NU8005T , rebooting , no picture , no backlight
                  by rui4892
                  Good morning.
                  the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well...
                  01-18-2025, 03:15 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
