TVs diodes…
Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
No, have none, if you think one of them is the problem you can remove one at a time and check it, the tv will likely work without it. Maybe remove one try it, no difference, put it back on and remove the other etc.Comment
so its... blocking all ckv are same to disconnect... this why need reduce yours masking. however i have doubt ... but you can try all 8 CKV messure them against TV chassis ... U ribbon should be disconnected.. check if you find one or 2 low ResistancesComment
I'm not sure I understand. would like me to measure between the chassis and the ckv? If so, can you please point out in one of my pictures where the CKV lines are on the board?Comment
this what you wrote... the U ribbon when you disconnected... the pins you masked before at the socket pins measure them in Ohm against GNDComment
it sound to me you have issue in glass panel gate transistor .. install the jumpers of Feed back which easybone advised at post #3 and disconnect the U ribbon we are talking on... if no picture displaying... then MB need to replace... but keep in mind the damage at gate transistor which make damage at T-CON circuit at original MB could happen too after short time at the same test advised here.Comment
I installed the jumper again, removed the left side of the U ribbon cable and I do get a picture on 3/4 of the screenComment
screen buffer board many video they fix it some of them just take away some caps thats it not even replace them search you l se before you throw it .Don't give up, you've been helped by wonderful people here, be sure and keep going, they will absolutely help you if you do what they ask you to doLast edited by bohaboha; 02-05-2025, 09:51 PM.Comment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by rui4892Good morning.
the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
