Samsung UE55NU8005T , rebooting , no picture , no backlight
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    Good morning.
    the original board of this equipment is in reboots without giving an image or turning on the backlight, the board code is BN94-12926P (BN41-02636), I made a copy of the flash ic1603 and ic1604, dumps attached. I tried to put other dumps (from other popis models I didn't find this board) but without success. That said, I bought a board on ebay BN94-12926A, which in principle should at least give image, even if with defects, this board turns on and responds to the command but does not give any indication of image despite the availability of VHG and VGL voltages as well as the others. with the doubt that the panel was damaged I took a board of model QE55Q70R (BN94-14330B), with this board gives image, although with some vertical lines that can be seen in the attached photo, that is, I effectively deduce the panel is ok, but it does not seem to be fully compatible with this board.
    Can you please check if the dumps of the original version are ok? Thank you.​
  • Diah
    • Feb 2013
    • 6565
    why yours SPI W25Q40BL, it should be W25Q40CL, as i know... so you need another version of programmer.. how ever all 3 spi are in tact
    • rui4892
      • Mar 2017
      • 57
      • Portugal
      My programmer for read/write that devices is the XGecu Pro TL866II-Plus, it automatically detects the flash parameters, such as manufacturer, capacity, ID, etc... I've been using it for a few years and without any problems so far, I don't think the problem should come from there.
      thank you.
      • Diah
        • Feb 2013
        • 6565
        i wrote all 3 dumps are fine.. but the name detected wrong.. you can read the Chip label you will see its W25Q40CL
        • rui4892
          • Mar 2017
          • 57
          • Portugal
          Sorry my friend... I didn't read your answer carefully, so I definitely have 2 boards with problems other than the eeprom... thanks anyway.
          • Diah
            • Feb 2013
            • 6565
            i don't think you have 2 MB defect.. but panel yes.. you can compare the LVDS socket configuration and pins over all 3. boards..
            • lotas
              • Jan 2016
              • 4862
              • Russia
              So, where are your dumps? I don’t see them?
              • rui4892
                • Mar 2017
                • 57
                • Portugal
                Originally posted by lotas
                So, where are your dumps? I don't see them?
                I'm sorry, I don't know what happened, I didn't edit the topic but in fact the dumps disappeared from the initial post, I don't think I broke any rules, until the user "Diah" saw them... I'll post here again. thanks
                • lotas
                  • Jan 2016
                  • 4862
                  • Russia
                  Dumps 25Q40, 25Q80 you are fine, the problem may be in eeprom 24C512 and eMMC, the panel settings are also in eeprom 24C512, you also need to pay attention in the t-con area there are positional resistors, they are set correctly for each panel model .​
                  • rui4892
                    • Mar 2017
                    • 57
                    • Portugal
                    hello again... Next Monday, when I return to work I will compare the two boards next to the TCON area, the panel in question is BN95-05417A 55S1AU0SN, the board I bought from ebay was, according to the seller, a broken TV. Have a nice weekend and thank you very much for your support.
                    • rui4892
                      • Mar 2017
                      • 57
                      • Portugal
                      good morning.
                      back to work. I photographed both boards and only modified the resistors on board A (ebay), the areas where I intervened are marked with a circle. No legible image has yet appeared, just vertical scratches... unfortunately I don't have a manual and I'm not sure which resistors to modify, if it's possible to have access to this information or the board's manual that would be great... thank you.​
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • ohren
                        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                        by ohren
                        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                        The models launched in 2018 and 2019 respectively....
                        09-08-2023, 05:24 PM
                      • C152Heavy
                        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                        by C152Heavy
                        Summary for TL-DR readers:
                        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                        • Have obtained Samsung schematic & service documents - Can upload if helpful.
                        • Have read ALL applicable threads
                        • C1818 and CP820 replaced as low hanging fruit
                        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
