LG 50PA4500 Clicking troubleshooting HELP please...
  • Fwrothy
    • Feb 2014
    • 178
    Re: LG 50PA4500 Clicking troubleshooting HELP please...
    Originally posted by skyver
    i cant post a new topic as im a new member but
    I have a 60PA6500
    It switches between either
    *constant relay click
    or
    *stuck in some standby mode where the screen is on but blank , power LEF is red and control board D101 Led blinks fast then slow then pauses
    weird thing is every now and again the TV works fine for a few days then back to this.
    when its in its constant relay click boot it will do this with just the power and main board connected and all other boards unplugged
    any help an ideas?
    POWER SUPPLY EAX64276701/11 EAY62609801
    You should probably start a new thread for this since its a different TV and problem...
    Read this, https://www.badcaps.net/forum/announcement.php?f=24
    Try to read the other stickys on the top of TV troubleshooting page on how to proceed.
    • BigPete
      • Jul 2012
      • 70
      • New Zealand
      #42
      In regards to the 1250v 22nF PP cap that needs replacing, can a Pilkor 1600v 47nF PP be used as a replacement? I have 2 of these lying around doing nothing. Failing that I have a 1250v 47nF and a 1250v 39nF in spare power supplies that could be borrowed. Failing that I can order one as well. Would it be wise to order a 1600v 22nF just to make it a bit more failure proof?
        It needs to be 22nF. 1250V or 1600V should be ok. Maybe 1600V will have a longer lifespan.
        • BigPete
          • Jul 2012
          • 70
          • New Zealand
          #44
          Thanks for that Tom.
          • BigPete
            • Jul 2012
            • 70
            • New Zealand
            #45
            Ok. The capacitor replacement went well. The TV ran fine for 2 days then stopped. I took it apart again checked everything, took out the top buffer board and the tv fired up on the bottom half of the screen. The model of the tv is 50PM6700. It is a 3D tv, but I have found it has the same panel as The PA4500 and PA6500 and probably others. I looked for the plastic tab that breaks and cuts into the ribbon cable on the top but can't find it. The top IC on the buffer tested bad. What is the chance of it being just the buffer. From what I read it looks low.
            Cheers
            Pete
            • BigPete
              • Jul 2012
              • 70
              • New Zealand
              #46
              Bump
              • Symlink
                • Mar 2015
                Originally posted by Fwrothy
                Ok new cap in and board remounted in chassis...
                Left all cables but AC disconnected.
                Powered up psu-ONE RELAY CLICK!
                Checked voltages at main cap- ~390vdc
                Jumped M-on to STBY, all voltages including VSTP & VATP check out.
                Power down, reconnect Y&Z sus cable and main board cable.
                Plugged it back in and it Works!
                To piggyback on this same issue: I replaced the cap, all voltages check out. I get one click without mainboard connected, one click with m-on and stby jumpered, and repeated clicks when mainboard is connected. Mainboard needs replacing?
                • husky601
                  • Apr 2015
                  • 36
                  How i can put a picture here? I did a schematic of the LG PA50PA4500 and i want to ask some questions. Thanks
                  • husky601
                    • Apr 2015
                    • 36
                    So here it is.
                    I can unplug any wire or ribon and the clicking noise does NOT stop. Clicking as soon i plug in it without pressing on any buton. Only way to stop the clicking noise is unplug the conection between point 2 to 2(power suply and main board) If my understanding is good i am supos to get 17v from ground to where is the blue wire but i get nothing. After that im kind of stock and don't know where to go. Hopefully someone is gonna be able to help me. Thanks guys!!
                    Alexis
                    • husky601
                      • Apr 2015
                      • 36
                      Hey guys,
                      i just did test the power suply board it self on my work table and if i plug the power cord on it i get 47 vols on every pin of both connector, the one going to the ZSUS and the other going to the main. After i did re-instal the board on in the tv panel, plug the power cord on it without pluging any of the 2 boards and i get 0 volts on any of the pins conectors. Unscrew the panel then test it again in place but without any screw and back to 47 volts on every pins. There is something i don't understand here.... Thanks
                      • Mike Hutchison
                        • Jun 2015
                        • 5
                        • united states
                        #51
                        Originally posted by Hamie
                        Ok so unplug the lead on the mainboard and put in your jumper between PSON and Stby
                        Usually it's pin1 - pin3
                        Hook it up like this:
                        Turn on powersupply if it continues to click over and over then your power supply is at fault.
                        Its more than likely will be your power supply at fault as there seems to be a common problem with C822.
                        See if there is any evidence of overheating etc, as it's a known fault Id replace that first before purchasing a powersupply as it will more than likely develop the same fault eventually.
                        Model Number or Part Number: 223J 1250V (22nF)
                        Repair KIT for LG Power Supply EAY62609701,
                        Capacitor 223J 1250V (22nF) replace capacitor at location C802.
                        This is a common failure item that can usually be diagnosed with visual inspection. The original capacitor installed at location C802 in LG power supply EAY62609701 will often bulge or deform causing a symptom of repeated cycling of the relay.
                        If BLACK C802 CAPACITOR on your board, REGARDLESS bulged or not, replacement of C802 is a MUST before any trouble shooting.
                        • SDJackson
                          • Oct 2015
                          Originally posted by hamie
                          ok so unplug the lead on the mainboard and put in your jumper between pson and stby
                          usually it's pin1 - pin3
                          hook it up like this:
                          turn on powersupply if it continues to click over and over then your power supply is at fault.
                          Its more than likely will be your power supply at fault as there seems to be a common problem with c822.
                          see if there is any evidence of overheating etc, as it's a known fault id replace that first before purchasing a powersupply as it will more than likely develop the same fault eventually.
                          i had the same issue and just changed out that capacitor... Tv works great! Thanks
                          • dkneyle
                            • Dec 2013
                            • 441
                            I'm about to do a repair for a guy who has this fault. I've located a metalised polyester cap of 0.022uf 2000VDC however it is cylindrical rather than rectangular. The cost to land one of the repair kit caps from the USA is prohibitive so I want to source locally. Anyone see any issues with what I'm proposing? To me it just seems like a mechanical difference. The cap is rated for high pulse frequency, so it also appears to meet that requirement.
                            • dkneyle
                              • Dec 2013
                              • 441
                              Replaced dodgy capacitor with metalised polyester in cylindrical format and the owner reports TV works fine again. Old cap was only measuring about 0.005uF (about 5nF rather than 22nF).
                                It is polypropylene type cap made for high frequency pulse, regular polyester will not last, so keep an eye on it.
                                • dkneyle
                                  • Dec 2013
                                  • 441
                                  My mistake in the post. Pretty sure it is polypropylene. I made sure it had high frequency specs and would do the job.
                                  • jeff52
                                    • Feb 2016
                                    • 4
                                    Greetings, I am a new member who has a similar problem with my LG 50PA4500, but I don't have the constant clicking.
                                    When plugged in, there are no lights in front, but one red light on the main board. When I push the on button, the front light blinks red and the stays red but no picture.
                                    In following this thread, my C802 capacitor is not bulging or deformed in any way, unplugging Y and Z doesn't affect the front light. But there is a hum when I first plug the TV in which is not there with the Z unplugged.
                                    The voltage on VSTP is 140v and on VATP is 50v. With Z and Y unplugged VSTP changes to 200v and VATP is unchanged.
                                    I am new to TV repair but have done some work on vintage audio.
                                    Any suggestions?
                                    Thanks,
                                    Jeff
                                    • jstiene
                                      • Feb 2013
                                      • 148
                                      Hello. I also have a question regarding a 50PA6500 with power supply EAY626097901. The TV does turn on and audio works fine, but no video at all. My question is whether the known bad cap at C802 could cause no video with audio ok. Just thought I would check before starting to troubleshoot the sustain boards...thanks for any suggestions..
                                      • Dandog96
                                        • May 2016
                                        • 4
                                        While everybody is asking questions, I'd like to chime in with mine. I am experiencing the clicking relay and brief red light flash on the front panel that everybody seems to be experiencing. Thing is, the C802 cap on my power supply is Blue and does not appear to bulge. It has not been replaced and is 1250v. Could this capacitor still be at fault even if is not bulging? I notice Brentsky also had a blue capacitor and changing helped him. I would appreciate some input. thanks
                                        • Brentsky
                                          • Oct 2013
                                          • 46
                                          It's entirely possible that the cap is still bad. It does not need to be bulging or discolored to be bad. The one I had to replace didn't look bad at all really. These aren't standard caps where the tops split and discolor. have you disconnected the board in order to rule out a shorted X-Sus and Y-Sus board ? If you have done that and the results are the same then i would replace the cap at C802. If your unable to find one I have quite a few. I can give you one. Simply cover the shipping cost which would be $2-$3 via 1st class mail
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            Yesterday, 02:18 PM
                                          • B0r1s
                                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                            by B0r1s
                                            PSU - BN44-00878A
                                            Symptoms:
                                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                            A weak clicking sound was coming from the transformer.
                                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                            Progress:
                                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                            01-17-2023, 04:58 PM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
                                          • slimmy182
                                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                            by slimmy182
                                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                            Looking on google I found this:...
                                            01-14-2023, 11:55 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
