Simple cap question.
    Can I replace a 2700uf electrolytic cap @16v with 4700uf cap @16v? having trouble sourcing locally, thanks.
    Re: Simple cap question.
    Not really its too big a gap - you can usually go 1 step higher so 3300.
    cpc have them but you have to buy 5
    http://cpc.farnell.com/panasonic/eeu...20This%20Range
      Yep, I've tried locally but no go, just 4700uf, looks like Ebay it is, thanks by the way.
        You can solder a 2200uf and a 680uf in series and get 2880uf or any combination of caps to make the uf value you need in a pinch.Try to use caps of about the same size. Don't worry if the voltage value goes up, that's ok. I do that sometimes just to see if the tv works. I always put the right cap in when it arrives in the mail. Just a thought. Good Luck
          I wouldn't buy caps from ebay, Selldoor has it right, try CPC
            I believe that is actually incorrect you would need to have the 2 smaller value caps in parallel - not like resistors
            http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
              This is absolutely correct.
                I am so sorry I did mean parallel not series. I was getting my 5 y/o grandson ready for school. I must think before I type.
                  Selldoor, is right, buy through his source, but depending on the circuit, paralleling to to high a cap value can strain the circuit feeding it. Splitecretes parallel would work OK, and JJR is right as well, don't buy caps from E-bay!
                    What is Splitecretes parallel? I'm unfamiliar with that term.
                      "You can solder a 2200uf and a 680uf" (he said series, but meant parallel)
                        Oh, I'm sorry. It's the guy's name. Doi!
                          HA! It's fine!!!!!
                            CPC free 3-day delivery with ANY order, and GUARANTEED to be good quality genuine source.
                            I bought Nichicon from eBay, actually was sent Nihoncon...!! Do not buy capacitors from eBay unless there is no other option!
                              One thing to be aware of is. If the capacitor is used in timing , it can trow off the frequency that iit was deigned to operate at and cause other issues. Example is cap in 5vdc standby circuits. This is usually a ESR or Capaciitance value change issue causing the circuitry not to work
                                So I changed the offending 2700uf cap for a 2200uf and 1000uf in parallel, Tv is now working perfectly, been on for over 6 hours without fault so thanks for all the help and advice, it's much appreciated.
