2700uF instead of 3300uF
  • Satdude
    • Aug 2020
    • 19
    • Czech Republic
    Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: 2700uF instead of 3300uF
    It usually depends on the ripple and esr of the original caps. If this is for power filtering going down in capacitance is usually not a big deal in most cases
      • 31144
      look at the xbox threads
        master hoarder
        • May 2008
        • 12175
        Should be fine, assuming you use FR, FM, or FS series.
        In terms of capacitance, 2700 uF is within 20% of 3300 uF... so OK to do.
        Linking this for the O/P:
        This is the thread itself:
        https://www.badcaps.net/forum/showthread.php?t=48951
        And this is the last iteration, if you want to save yourself some reading:
        https://www.badcaps.net/forum/showpo...&postcount=196
        • Behemot
          • 4845
          • CZ
          If we are talking low-ESR (not ultra-low ESR like those on later PC motherboards), I do have both Chemi-Cons KYA and KYB 3300/6.3 on stock, they differ in life endurance, ESR/ripple current and size (KYA 5 mm shorter). Also do have SOME ultra-low ESR caps, or you may try polymodding it arround the CPU. Why didn't you check first?
