Funai LF320FX4F Power Supply Issue?
  • trs71
    • Jun 2014
    • 11
    • Usa
    I'm the pround owner of a Funai LF320FX4F $98 Black Friday Walmart Paperweight. It Turns on for about 3 or 4 seconds sometimes a bit longer, just enough to see a picture, and promptly goes out. I assume it's the power supply PN# BA3AF0F01023.
    I could order one off of ebay for $20 but where is the fun in that. The board has nothing visibly wrong that I can see, and of course I can't find any trouble shooting schematics for this thing. Any ideas on a good place to start?
  • R_J
    • 9550
    Re: Funai LF320FX4F Power Supply Issue?
    You could start by posting some pictures of the boards
    • Ltank
      • Jun 2013
      • 776
      If the fuse is blown check the mosfet for shorts to ground. All three legs would be shorted to the
      Heatsink
      • trs71
        • Jun 2014
        • 11
        • Usa
        I was going to post a picture and I can take one but the Ebay zoom picture is better probably than I can take.
        It's identical, nothing burnt or discolored on mine. I can post a pic of top and bottom when I get back if needed, a quick test I believe, shows D608 (by the big cap) to be shorted. The fuse (F602) tested good.
        • trs71
          • Jun 2014
          • 11
          • Usa
          PICS
          [/URL][/IMG]
          [/URL][/IMG]
          [/URL][/IMG]
            Can we see the bottom side of the power supply board? The power MOSFET must be on the bottom side of the board which will be strange since it will require heatsink. Also pictures of the whole back side of the TV. It seems to me that this a sub-power supply, not the main power supply.
            It looks like LED Backlights TV.
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              d608 looks like a zener from the board desination, pull it out of circuit and retest to see if it is shorted or something else in the circuit. I fixed a funai last week with only a single failed zener diode, you may get lucky.
              Liberating magic smoke one part at a time
              • trs71
                • Jun 2014
                • 11
                • Usa
                Sure PCB pic
                I only have done some basic repairs on arcade monitor and the such and lcd tv's but this doesn't even look like a power supply to me....
                [/URL][/IMG]
                  One of those cheap two transistor Osc power supply. Did you check ALL the Diodes on the board for shorts?
                  • trs71
                    • Jun 2014
                    • 11
                    • Usa
                    Didn't see any other shorts, I'll do test again after work.
                    D654 is a Zeiner, but it shouldn't be conducting both ways (leaking) with an lcd meter diode test should it?
                      "D654 is a Zeiner, but it shouldn't be conducting both ways (leaking) with an lcd meter diode test should it?" That ZENER may be connected in parallel with the low Ohm Source resistor, so you need to lift one leg of the Zener and test it again.
                      • trs71
                        • Jun 2014
                        • 11
                        • Usa
                        Once D608 is out of the circuit it seems fine, D654 looks ok too. No other diodes test bad on the board.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          Have observed that Pwr boards with BAXXF0F01022, etc from manufacture FUNAI are poor quality and if you are successful in repairing they don't last too long.
                          • Caleb
                            Smokin IC's
                            • Feb 2013
                            • 645
                            have you checked all the diodes on the reverse side for shorts as well? I can see at least 4
                            • bammbammfran
                              • Apr 2014
                              • 476
                              your problem might not even be with this power supply board.
                              Could be the main board or you may have a problem with the led lighting in the panel
                              I do not seem to see any mention to voltage testing and results
                              Since it turns on a bit, the voltages should be monitored in off state and on state and after it shuts down
                              • bammbammfran
                                • Apr 2014
                                • 476
                                Check voltage at the two red areas
                                use the black circled area as a ground.
                                Check this power with the board by itself
                                then plug in the input board (do not connect the actual screen panel yet) and check them again.
                                then with a video source connected , power on the unit and check them again
                                If the voltages stay steady and do not drop, the board might be ok
                                so then we'll have to check power to the panel
                                • trs71
                                  • Jun 2014
                                  • 11
                                  • Usa
                                  Mr
                                  Sorry I haven't got back to testing it till now, family stuff and all.
                                  I tested every thing unplugged and plugged in, (input & screen) and had power of 10.9v on two diodes and 6.5v on the other two at all times. I also (a week ago) went and bought a cheap used power board because of the problem with the previous reversions of it, and of course it does the exact same thing.
                                  Powers on, power light flashes 17 times, I see the Funai logo and...nothing steady power red light, no pic. It seems to be picking up a video signal with a HDMI hooked up to my pc video card. The pc kept recognizing a display being connected.
                                  Thanks for the help so far, with the number of these bought and the failure rate already (from my searching) I'm sure this model will soon pop up quite frequently.
                                  • trs71
                                    • Jun 2014
                                    • 11
                                    • Usa
                                    Since the power supply seems ok, what should I check next the main board or? Not sure what I can check on there, I get a clear Funai logo for a few seconds and that's it.
                                    • TJVJR
                                      • Jul 2013
                                      • 25
                                      Did anyone find the solution? I have the same model with the same problem .
                                      • trs71
                                        • Jun 2014
                                        • 11
                                        • Usa
                                        I sure didn't, It seems the voltage was correct for the momnent it was on, but I switched out the power and the main boards with "working" ones, tried disconnecting all the plugs and powered up each time also with no change.
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
