Westinghouse SK-32H540S Catastrophic inverter Transformer Failure.
  • Shinju
    • Mar 2014
    • 1239
    Hello friends!
    I got this for free, got it home and plugged it in, I turned it on and I see the blue power light and nothing else, I started to hear a high pitch squeal and and after a minute that went away.
    Fast Forward a couple of weeks, I finally get some time to tear it down and before doing so I hooked it up to a source to see if there was audio and there was, you can also see a picture with a light to the screen YAY mainboard is good!
    Anyway so I broke it down and after tearing the back off I see the PS/Inverter are on the same board... Ugh, Also saw that the bottom transformer was pretty melted eeps!
    So I pulled the board out and this is what I found! (see below)
    Question, I see the people have had luck with replacing the single blown transformer and the panel has been working fine, on the other hand MOST who have done that single transformer fix find out they blow the new one in about 10-40 seconds.
    Should I replaced all 3? The blue caps next to the formers have no markings on them at all at least none that I can see should I replace all those too?
    Or should I just try and find a donor board and toss this one out?
    I want to know if anyone has figured out what causes this to happen so it can try to be prevented?! This seems to be a very common affliction on this series of Westies!
    Thanks!
    Re: Westinghouse SK-32H540S Catastrophic inverter Transformer Failure.
    Well, it is DARFON after all, replace many of their transformers. You can expect the other two to fail later on also.
    • Shinju
      • Mar 2014
      • 1239
      Should I just replace all 3? I don't have an issues doing that, these boards seem rather spendy to gamble on another problematic transformer!
        I would do all three at the same time, some time the whole replacement board is cheaper than buying 3 transformers.
        • Shinju
          • Mar 2014
          • 1239
          Not sure what one to get, they all seem to have different part numbers but also seem to match the same board.
          http://www.ebay.com/sch/i.html?_odkw...%2F+D&_sacat=0
          High as 49.99 each to low as 8.00 each.
          • Shinju
            • Mar 2014
            • 1239
            Budm, do you have any in your parts bin you might be willing to sell?
              I do not know what I have, need to dig through my part bins. What is the P/N as printed on top of the transformer?
              • aaronwt6
                • Apr 2013
                • 855
                • US
                I just purchased some from this seller a few weeks ago. Took about a week to arrive which I thought was pretty reasonable with free shipping from China. I repaired two boards and both worked great afterward.
                http://www.ebay.com/itm/190816409569...%3AMEBIDX%3AIT
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  I will note that yours is burned more severely than my two were. The burns on mine were really only visible with the suspect transformer removed.
                  • Shinju
                    • Mar 2014
                    • 1239
                    4302H 805095 (GP)
                    Thanks aaronwT6, I will go that route next!
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      No problem. Good luck with the repair.
                        OK, I will look through my bins tomorrow at the recycling place to see if I have them.
                        • Shinju
                          • Mar 2014
                          • 1239
                          Thanks budm!
                            Well, I went through my bins, there is nothing that matches your transformer.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              ebay $6.99 ea.
                              had one worse than that.dremeled out the carbonised areas.
                              replace all 3 now or one at a time at a time of its choosing and a free air freshener too.
                              oh did i mention they stink a while even after the repair?
                              • Shinju
                                • Mar 2014
                                • 1239
                                All good budm, thanks for looking!
                                Kc8adu, do you have that link saved by chance for the 6.99 on ebay?
                                I am fixing this one for a son of a family friend who is doing a few weekends of yard labor for a tv to play his xbox 360 on!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Question, if one was to drill some small air holes on this board avoiding traces (seems to be a single sided board). Think doing that will help keep these transformers cooler and prevent over heating death?
                                  Or should I just leave it as is?
                                  • jetadm123
                                    • 2169
                                    Since your Darfon board is Model B070-601, this appears to be the correct transformer:
                                    http://www.ebay.com/itm/Inverter-Tra...item3f0ab39ceb
                                      • 31284
                                      probably a good idea to check the 4 blue caps connected to it before powering up with a new transformer.
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        Pretty sure the board is toast, uploading photos here soon.
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • eccerr0r
                                          inverter H tree driver imbalance in an AC inverter
                                          by eccerr0r
                                          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                          Yesterday, 12:34 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
