take the screen out.. and never put it back unless yours BL remain on always.... tv will work with out screen too
Sony KDL-46ex700 led replacement still same issue
I'm here again, so I already inverted the strip and I have the same problem so the problem is on the board. I took some measurements and on the side of working both strips led i have almost 240v (both)120 one and 120 one. The other side where leds doesn't work in have at max 40v (80 both). The colours of the wire of bad side are 2 blue... the good side the wire are red.. That's a real challenge 😫Last edited by labello; 12-03-2024, 08:46 AM.Comment
wrong from me , the small socket LED+ for all.... and large socket 2 are LED -I'm here again, so I already inverted the strip and I have the same problem so the problem is on the board. I took some measurements and on the side of working both strips led i have almost 240v (both)120 one and 120 one. The other side where leds doesn't work in have at max 40v (80 both). The colours of the wire of bad side are 2 blue... the good side the wire are red.. That's a real challenge 😫
Nope... i didn't touch anything. I would like too if that was the problem but im afraid the clips can't be exanged. ..(see picture) One is a bit less than the other.. maybe I'm wrong, but probably there's some component that cause this problem..2 PhotosLast edited by labello; 12-03-2024, 01:04 PM.Comment
you need to undestand what i am talking
you have 2 soclets both are correct no need to do any for them..
the small socket have blue and red this both LED + connected to gether..
the large socket have also 2 one red and blue... this lines are each out LED - now the red on this latge socket working.... but the blue not.... you need to flip the PSU and follow the track line of the blue one you will have Diode and many other sync smd R need to check if one openComment
Yea .... I was thinking about reverse engineering, by following the road back...Tomorrow i will also back pannel in place. I'll let you know. Have a good evening for now thanks
Hello guys I finished to take a look around diode smd and resistor smd , no open circuit, the only strange measurements that I discovered is in component that i mark red circle on picture, I only have one measurements i don't know if it's the anode or cathode, the other around it i have anode and cathode. So I suppose it's could that the problem..? Thanks for your answers2 PhotosComment
Well that's good, can you describe the solution? Or did you give it? All I read was it's working now.Last edited by nomoresonys; 12-30-2024, 06:36 AM.Comment
Hi.Yes at last wast bad connection of the negative rail including the little capacitor on the secondary side. That's why I didn't have any power on the one side of led..Comment
looks like Diah was on that path in post # 47. Bad soldering is often overlooked. More than once even, my bad soldering that looked good was the issue.Last edited by nomoresonys; 12-30-2024, 05:41 PM.Comment
by timonix20hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
the TV starts, LG logo, then nothing (rear backlight)
no reaction to rear command or infrared
the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
I have a chance with a usb procedure or other if you have .bin
if any people have this main board
Sony LG 60la620s EAX64797004 (1.1)
thank you... -
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... -
by ltiI'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
by ScHAmPiHi all,
Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...2 Photos -
by eclectricHi, I'm hoping someone can help me with this issue before I give up on this TV.
In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes... - Loading...
