Sony KDL-46ex700 led replacement still same issue
Yes it disappear rapidly, so I decided to take those off again and giving testing and both are okay, but then I look around and with a pen drive I discovered another mess look all of legs are moving so I cleaned and resolder those but one can't soldering because who touch this board long time ago doing bad work with soldering. My god it's a nightmare 😫2 PhotosComment
Hey bro finally the tv work!! on primary side I have almost 800v (both capacitor) and 3.3 standby back also! But if I move the tv ( tv live mode) after about 5 seconds it turning off and no indicated of red light just black out , and doesn't want to start on again, i want to test it on hdmi output and we'll see may the problem is on tuner board itself...Comment
I know what you think but im not a manster to find problem 😂 thanks1 PhotoLast edited by labello; 11-16-2024, 12:42 PM.Comment
these are the main switching power mosfets, not diodes, it's completely useless to check voltage on these components and also risky, you have to check voltage first on the power diodes of the secondary.. if it is present, then the primary is ok..Comment
Hello , first of all, thank you for your guidance second i don't have any power on the secondary side I checked all only in the pictures circled have 1.6 voltage the rest of them 0 voltage. Also the single diode 0 voltage.. so if I understand there's some protection that stop the primary to work right...?Comment
I took the board off the tv and check if I have standby voltage and magically i have it so I'm almost going crazy or I'm going to be stupid ,because if i place the power supply on tv I don't have 3v standby I don't understand that it's a nightmare 😔😫2 PhotosComment
OK, test the power board alone, connect a jumper between Power-On , tcon-On 12v and Standby 3.3V, check every output V possibly with dummy loads, a resistor on standby 3,3v and a car lamp on 12v.. then if good, connect back lights and jumper also BL_ON, check again voltages and if back lights turns on..
...now i watch Tennis.. Go Sinner!..Comment
by timonix20hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
the TV starts, LG logo, then nothing (rear backlight)
no reaction to rear command or infrared
the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
I have a chance with a usb procedure or other if you have .bin
if any people have this main board
Sony LG 60la620s EAX64797004 (1.1)
thank you... -
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... -
by ltiI'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
by ScHAmPiHi all,
Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...2 Photos -
by eclectricHi, I'm hoping someone can help me with this issue before I give up on this TV.
In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes... - Loading...
