Sony KDL-46ex700 led replacement still same issue
  • labello
    • Mar 2018
    • 295
    • italia
    #141
    looks like Diah was on that path in post # 47. Bad soldering is often overlooked. More than once even, my bad soldering that looked good was the issue.
    Yes, he was right. Oh, you too have bad soldering , seems it's a problem by fabrication board
    • timonix20
      Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
      by timonix20
      hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
      the TV starts, LG logo, then nothing (rear backlight)
      no reaction to rear command or infrared
      the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
      I have a chance with a usb procedure or other if you have .bin
      if any people have this main board
      thank you...
      04-23-2024, 01:52 PM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
    • lti
      Sony MDR-IF245R transmitter LED replacement
      by lti
      I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
      06-28-2024, 01:47 PM
    • ScHAmPi
      Samsung UE48JU7000 screen issue after backlight replacement
      by ScHAmPi
      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
      07-15-2024, 05:41 AM
    • eclectric
      Sony Bravia KDL-70W850B T-CON board / software update issue
      by eclectric
      Hi, I'm hoping someone can help me with this issue before I give up on this TV.
      In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
      Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
      I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
      05-23-2022, 01:25 AM
