Sony KDL-46ex700 led replacement still same issue
  • labello
    • Mar 2018
    • 252
    • italia
    #41
    [QUOTE=Davi.p;n3505982]This is a more complex scheme than usual ones, like Sony habits, i can't read well from photos on a cellular, sorry, but i'm almost sure you'll find the 2 components burnt..[/QUOTE
    Hi, 2 component burn? I find only one the fuse..If you tell me what side of the board you need, I'll try my best to get a good picture. Anyway, what's the right replacement fuse? i will buy
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      #42
      no , i haven't asked more photos!... read well back posts, i asked to check components..
      • labello
        • Mar 2018
        • 252
        • italia
        #43
        Okok I'll do it after lunch that I have a bit time
        • labello
          • Mar 2018
          • 252
          • italia
          #44
          test Q6814 (TO220), R6850 (2W resistor)
          Hi resistor 2w give me this results you can see the picture, the q6814 test okay
          • labello
            • Mar 2018
            • 252
            • italia
            #45
            The tv is completely dead, i take some measurements and i have wrong results , relè doesn't want to turn it on . I really don't know what's going on now..😔 Thanks
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              #46
              Watch under the big inductance L6800, under side, a little higher, there are 4 smd diodes, check them and also on top left zone, the 2 power smd mosfets..
              • Diah
                • Feb 2013
                • 6435
                no defect parts... just bad joint soldering.. check path track and resolder T6103 and a rround it
                • labello
                  • Mar 2018
                  • 252
                  • italia
                  #48
                  Hi i really looking deeper i didn't find anything strange. Thanks
                  • labello
                    • Mar 2018
                    • 252
                    • italia
                    #49
                    Ok i will check later
                    • labello
                      • Mar 2018
                      • 252
                      • italia
                      #50
                      Hi i check what you said, unfurnished i didn't find anything strange, diode smd all good also smd mosfet , i found 2 if there's capacitor smd with verità lower resistance (photos circled) and in the primario side I take out both capacitor to measure in right way they have lost 20 uf . So not 150uf but i have measured 130 uf. Thanks
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4456
                        • Italy - Milan
                        #51
                        what are circled are resistors... 130uF are not a problem..
                        • labello
                          • Mar 2018
                          • 252
                          • italia
                          #52
                          I see, it's strange because before i have the standby voltage and the tv turn on regularity... The only doubts that i have is about this capacitor i don't know if i replace it with correctly voltage. The schematic for this board doesn't exist? Thanks
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4456
                            • Italy - Milan
                            #53
                            I suggest to not replacent that cap, usually Sony boards have good solid caps, you have to know that when you do measurements you must before discharge the big 400v caps
                            • labello
                              • Mar 2018
                              • 252
                              • italia
                              #54
                              I always discharge the big capacitor before I'm going to touch the board, so without the schematic we can't understand what's going on on this board🙄
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4456
                                • Italy - Milan
                                #55
                                I'm at work now, i have not much time to examine, let's see at evening..
                                • labello
                                  • Mar 2018
                                  • 252
                                  • italia
                                  #56
                                  Me too, let's try later 👍 thanks
                                  • labello
                                    • Mar 2018
                                    • 252
                                    • italia
                                    #57
                                    Hello David I really tired for today I just went to home.. Can you tell me what I should check, I'll do it tomorrow morning. Have a good evening thanks again
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4456
                                      • Italy - Milan
                                      #58
                                      Sorry, i was unable to download the First pictures, now i managed to do it and i saw your measurements, so the test i made you do until now are pointless, you have to check the voltage on the center pin of the two double diodes you removed at the beginning, especially the one that feeds the backlight circuit, after, have you tested the led bars with a led tester?
                                      • labello
                                        • Mar 2018
                                        • 252
                                        • italia
                                        #59
                                        Hi morning, I'm sorry but I don't removed any doubles diodes, only one leg an testing in diode mode. You mean those little diodes close of the little transformer.. or the heatsink ? Yes the strips led was ok before I installed
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4456
                                          • Italy - Milan
                                          #60
                                          I'm referring to the post #7 when you dismounted the double-double diodes on heatsink...
                                          each one is a two diode with common cathode..
                                          • timonix20
                                            Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
                                            by timonix20
                                            hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
                                            the TV starts, LG logo, then nothing (rear backlight)
                                            no reaction to rear command or infrared
                                            the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
                                            I have a chance with a usb procedure or other if you have .bin
                                            if any people have this main board
                                            thank you...
                                            04-23-2024, 01:52 PM
                                          • ezenia
                                            PS4 controller left stick potentiometer replacement issue
                                            by ezenia
                                            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                            09-30-2023, 02:19 PM
                                          • lti
                                            Sony MDR-IF245R transmitter LED replacement
                                            by lti
                                            I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
                                            06-28-2024, 01:47 PM
                                          • ScHAmPi
                                            Samsung UE48JU7000 screen issue after backlight replacement
                                            by ScHAmPi
                                            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                            07-15-2024, 05:41 AM
                                          • eclectric
                                            Sony Bravia KDL-70W850B T-CON board / software update issue
                                            by eclectric
                                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                            05-23-2022, 01:25 AM
