Toshiba 20W300PG No backlight
  • playman
    • Jan 2011
    • 252
    Hi there
    I have a Toshiba LCD TV that has black screen (no backlight)
    but shows image when directed a light onto the screen.
    C347 & C338 (both are 470uf 25v chang) were bulged, I replaced them with 470uf 25v su'scon I had here.
    Both fuses are ok, I only found 2.
    I noticed no change in that repair.
    What else could be the culprit?
    I hope the pictures are good enough, I took them with my galaxy s3 phone.
  • playman
    • Jan 2011
    • 252
    Re: Toshiba 20W300PG No backlight
    No one that could know what's wrong?
    • flocko
      • Nov 2012
      • 1121
      have you checked white smd fuse f300 on back of board?
      • playman
        • Jan 2011
        • 252
        I checked it in circuit got no reading @ 200Ohm, switched to 200kOhm and got a reading of 53.1 then gradually
        lowering down to 39.7 which I stopped measuring, checked it again 3-4 Min later and got a reading of 1.7 @ 200kOhm
        and it gradually raised to 7.1 which is when I stopped measuring.
        Is that normal?
        I also noticed another fuse on the board F103 which measured 1.3Ohm @ 200Ohm
        I can always measure SMD fuses in circuit right?
        • flocko
          • Nov 2012
          • 1121
          the fuse should read the same as when you have the red and black leads together (short circuit)but must be measured across the fuse not to ground Flocko
          • playman
            • Jan 2011
            • 252
            yea that's what I did, I measured across the fuse, the meter gives me 0.8Ohm @ 200Ohm reading when I connect my leads together.
            Do you believe that the F300 is broken?
            • flocko
              • Nov 2012
              • 1121
              looks that way,if you have no new fuse to replace itwith use a fine wire across the fuse for testing only, if that works and the backlight comes on then you can get the correct fuse. Flocko
              • playman
                • Jan 2011
                • 252
                Ok I de-soldered the fuse and tested it and it was broken, it says 3 on it, that means 3A fuse right?
                I soldered a wire where the fuse was, plugged the TV in and saw a standby light, tried to turn it on and nothing
                happened, standby light changed into fast blinking and then few seconds
                later it disappeared and now it's like the TV is completely dead, No lights visible.
                Wire seems still be intact.
                No visible damage can be seen, no sound was heard or smoke/smell.
                All 4 the fuses (main, F102, F103, F300 wich is a wire) are okay, I just know of those 4.
                  • 31086
                  that was predictable.
                  something is probably shorted that made the fuse fail.
                  • playman
                    • Jan 2011
                    • 252
                    What can I do now?
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      remove the wire you put in and see if it returns to its previous behavior, if so you havent fouled anything else up yet, then work down the line and see if you can find shorted components in that section. I would look at that quartet of mosfets as likely suspects.
                      Liberating magic smoke one part at a time
                        Need to check those 4 SMD Power MOSFETS Q301~304 to see if it has S to D shorted out or have very low resistance.
                        • playman
                          • Jan 2011
                          • 252
                          After I removed the wire it seems to return to previous state, show's standby light and
                          turns on and I can see the menu with a flash light.
                          Then I would guess that D is pin 2 and S is pin 3 right?
                          Q301=Red probe on D(2) Black on S(3) = Open Cirquit (no reading)
                          Q302=Red probe on D(2) Black on S(3) = Open Cirquit (no reading)
                          Q303=Red probe on D(2) Black on S(3) = 188.4 @200Ohm
                          Q304=Red probe on D(2) Black on S(3) = 10.4 @200Ohm
                          Q301=Black probe on D(2) Red on S(3) = 1638 @ 2000kOhm then open circuit (no reading)
                          Q302=Black probe on D(2) Red on S(3) = 1677 @ 2000kOhm then open circuit (no reading)
                          Q303=Black probe on D(2) Red on S(3) = 53 @ 200kOhm and degreasing rapidly down
                          Q304=Black probe on D(2) Red on S(3) = 10.5 @ 200Ohm
                          Is it right to guess that all FET's are broken except Q304?
                            Looks like Q304 is definitely bad, Q303 maybe.
                            • playman
                              • Jan 2011
                              • 252
                              I did forget to mention that I measured them in circuit, sorry for that.
                              So I might as just replace them all, right?
                              Or are the Q301 & Q302 just fine enough to use.
                              Is there anything else that might have gone?
                              would be nice to know that before I try to order as there is no part shop in my town
                                Given the cost of four FETs is likely to be minimally more compared to just two, I would replace them all.
                                • playman
                                  • Jan 2011
                                  • 252
                                  I was about to order the parts when I noticed that the FET's have two different
                                  type numbers 2x STD30PF03L & 2x STD17NF03L, I hope that does not make the measuring bad.
                                  The problem is the STD30PF03L has not been available in the store here in Iceland since 2009, and
                                  Farnell their supplier don't have it either.
                                  Is there any other FET I can use instead of the STD30PF03L?
                                  http://pdf1.alldatasheet.com/datashe...TD30PF03L.html
                                  http://pdf1.alldatasheet.com/datashe...TD17NF03L.html
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • Boyxba
                                    TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                    by Boyxba
                                    I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                    05-13-2023, 11:47 AM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • willis6732
                                    Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                    by willis6732
                                    This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                    Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                    The Driver board looked pretty toasty in the LED Driver Area.
                                    So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                    12-17-2024, 04:09 PM
