Sharp LC-52E77U no pic. Or sound found dead cockroach under power board HELP
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp LC-52E77U no pic. Or sound found dead cockroach under power board HELP
    Poor connection to the laps most likely created this. It's like a bottle neck in current. The weakest point will melt.
    • mr.mroz88
      • Jul 2013
      • 52
      • florida
      Nothing looks burned on the board
      • freakaftr8
        • Oct 2012
        • 3743
        You may have to either search for the lamp holders or carefully solder a bridge with a wire from point to point now.
        • mr.mroz88
          • Jul 2013
          • 52
          • florida
          Ok, well what should i do with that
          • mr.mroz88
            • Jul 2013
            • 52
            • florida
            Oooh , alright so if i change those metal holders that will actually help?
            • mr.mroz88
              • Jul 2013
              • 52
              • florida
              #26
              Why iam asking because if i get luck and buy those somewhere will this happen again ?
                • 31185
                if you desolder the holders you may be able to reverse the contacts so the burned side is away from the tube.
                BUT the contact on the tube will also be burned.
                so you need to sand the burned contacts to clean metal - fit the lamps - then solder the joints really.
                btw, i'v never seen these before - only tubes soldered to long boards!
                to answer your question - it will happen again because the tube contact is burned and the design is bad.
                • mr.mroz88
                  • Jul 2013
                  • 52
                  • florida
                  #28
                  Ok, u saying "solder the joints really " do u mean joints between the holder and tube ?
                  Sorry about this stupid questions but thats the way i learn
                  Thank you
                  • mr.mroz88
                    • Jul 2013
                    • 52
                    • florida
                    #29
                    I mean there is nothing to solder , those metal holders are in i plastic "bracket " and the lamps just slide there , also the side where the lams are is not burned , only the pins that goes to the actual board .
                      • 31185
                      foto of the end of some lamps would help.
                      normally when a contact burns, both of the parts conected burn.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Kinda redneck but you can always try soldering to the end of the lamp. Wear safety glasses.
                        • mr.mroz88
                          • Jul 2013
                          • 52
                          • florida
                          #32
                          Ccfl
                          • mr.mroz88
                            • Jul 2013
                            • 52
                            • florida
                            #33
                            • mr.mroz88
                              • Jul 2013
                              • 52
                              • florida
                              #34
                              • mr.mroz88
                                • Jul 2013
                                • 52
                                • florida
                                #35
                                U can actually see that the holdet is not burn where the lamp slide in , its burn from the another side ... :/
                                  • 31185
                                  no, the clips are burned a bit too.
                                  the other side could mean it's a 2part clip and the burn is where they are spot welded together.
                                    • 31185
                                    looking closer i see the problem.
                                    atleast i think i do.
                                    the pin on the bottom of the clip that goes through the pcb is too thin to handle the current.
                                    that probably means the tubes are on the way out & drawing more current than intended.
                                    all i can think of is soldering thick copper wire to each clip where the pin used to be.
                                    use lead free solder - you'l probably need that higher melting point!
                                    long term, a friend of mine replaced the tubes in a few backlit tv's using strips of leds that come on 5m reels from china - it works petty well.
                                    • mr.mroz88
                                      • Jul 2013
                                      • 52
                                      • florida
                                      #38
                                      Thank you so much for your time that help me a lot ...
                                      Idea with diodes sound nice but i dont think i can do that :/
                                      Anyway i will check it out today thx
                                      • mr.mroz88
                                        • Jul 2013
                                        • 52
                                        • florida
                                        #39
                                        This is how the "holders " actually look
                                          OK, looking at your pictures, you have poor contact problem between the blade of the lamp socket, the C-clamp part of the socket that makes contact with the lamp is OK, it is the blade which shows black carbon marking is having problem making contact with black socket on the inverter board. You need to inspect those black sockets on the inverter board for contact corrosion/black carbon/burnt contacts. You need to clean the contacts real well.
                                          Is this the inverter board you have?
                                          http://www.shopjimmy.com/media/catal...tka529wjn1.jpg
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • paparazzo79
                                            sound card dead after graphics card installation
                                            by paparazzo79
                                            Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                                            The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                                            I still can not believe that I am such a looser and don't know...
                                            07-23-2024, 12:22 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • borstar_micke
                                            Dead Sharp Aquos LC-32LE430E
                                            by borstar_micke
                                            My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
                                            I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
                                            Not a master with the multimeter, which is cheap and 10-15year old btw...
                                            So please make it basic...
                                            To the issue at hand.
                                            As stated, the tv is totally dead with no standby light....
                                            03-23-2023, 09:14 AM
