Sharp Aquos LC52SE94U hit by surge
    Re: Sharp Aquos LC52SE94U hit by surge
    If the current sense resistance is different, then it would alter the output power available.
    Exceeding the limit would cause the circuit to fold back (I expect) leading to a sag in PFC bus voltage, which would eventually cause a sag in the output voltage of the power supply and/or other faults.
    It could also just cut out if a pre-set limit occurs, or skip pulses (probably more likely.)
    I seem to recall having a LCD TV with a PFC fault. The controller IC would become jumpy below about ~215V AC mains, the unit being rated for 100-265VAC. This was a rare event but would mean occasionally the TV backlight would flicker especially if things like a fridge had just started causing the mains voltage to dip.
    I think I found a spare PSU for that one and didn't fix the old one, but if I were to take a guess, I'd say there was a chance the controller was erroneously detecting an over-current an automatically folding back.
    Of course, the resistors could be the same. So you could draw more power. However, you'd start coming across other limits: the inductor might start saturating, which can cause excessive power dissipation in the MOSFET, damaging it. Or, the MOSFET could simply naturally run hotter, due to the higher load, leading to early failure.
    • Fwrothy
      • Feb 2014
      • 178
      So i will take that as, "it's possible" just not sure when I comes to impedance whether something like paralleled loads are akin to resistive loads.
      Would two MOSFETs each handling individual load of matched coils (which are in parallel), same duty cycle(incl. phase), share a total load through individual diodes to main caps and transformer primary input switching ?
        From Fairchild, the two outputs (drv1, drv2) of the IC are out of phase from each other.
        • Fwrothy
          • Feb 2014
          • 178
          I showed drive SCH in #95, both MOSFET drives identical( only one illustrated) parallel to pin 7 L6562D
          See above edit
          • Fwrothy
            • Feb 2014
            • 178
            The drive from the PFC IC, one of it may be get inverted to produce 180deg out of phase drive signal
            I read the first link, I think I get it:analogous to a two cylinder pump I think...
            Link 2 doesn't apply since we have a full bridge rectifier...
            The third strategy takes advantage of the entire wave form, also non applicable...
            These are all really cool stategies from what I have learned so far, probably better than what I am seeing in this supply; they are also probably more modern since this tv is a vintage '07 or'08 :-D
            • Fwrothy
              • Feb 2014
              • 178
              No more short!
              • Fwrothy
                • Feb 2014
                • 178
                ...for now anyway!
                Thank you Budm, Tom66 and everyone who contributed to this thread
                  Great!
                  • Fwrothy
                    • Feb 2014
                    • 178
                    Great!
                    Thanks again for all the knowledge and your patience especially
                    I guess I need a new project; got a couple of Yamaha AV receivers in the basement I scooped from the back of a tv shop, notice one had a blown fuse when hunting around for a tv fuse...think I'll start there
                      awesome!
                      Now to fix mine!!
                      • Fwrothy
                        • Feb 2014
                        • 178
                        Thanks Tom if only I had your knowledge!
                        Your site is such a great resource
                          Use the lamp again for troubleshooting.
                          You should build these:
                          http://s807.photobucket.com/user/bud...tml?sort=3&o=1
                          http://s807.photobucket.com/user/bud...tml?sort=3&o=0
                          http://s807.photobucket.com/user/bud...tml?sort=3&o=7
                          • Fwrothy
                            • Feb 2014
                            • 178
                            Sound advice! Will come in hand for my new project
                            • scubacamper
                              Sharp Aquos LC-70C6400U Half Screen Dark
                              by scubacamper
                              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                              05-03-2025, 12:19 PM
                            • jonah1024
                              Sharp Aquos LC-40UG7252E LCD TV burn in?
                              by jonah1024
                              Hello!
                              I'm a few days old into this TV screens repair universe so please bear with me.
                              Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                              - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                              - I did a factory reset as well...
                              07-16-2024, 04:23 AM
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • klassic
                              Sharp Aquos LC-60LE635E three blinks
                              by klassic
                              Hi community,
                              I will describe my problem with a TV in those short following terms to be the most precise :
                              What i have :
                              power board DPS-162KP-1
                              main logic board QPWBXF733WJN2
                              symptoms :
                              white led light logo at startup,
                              after 2 minutes, blinking 3 times a row, repeating
                              no backlight (and apparently no picture, checked panel with flashlight)
                              no startup sound
                              powerboard investigations :
                              1-2 PNL : 0v
                              3-4 GND
                              5-6-7-8 UR : 13.15v
                              9-10-11-12...
                              10-24-2023, 01:39 PM
                            • foxyUK
                              Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                              by foxyUK
                              Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                              The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                              There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                              10-22-2024, 10:27 AM
