Samsung LN37A550P3F with bad Gamma AS15 AUOPTO T-CON
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Samsung LN37A550P3F with bad Gamma AS15 AUOPTO T-CON
    I have one IC left you think I should pop it in ?
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      Originally posted by tom66
      The full readings would help.
      Soldering looks OK.
      Tibimaki replaced IC, and found new IC to be bad. So do not rule out chance you got a bad IC.
      ESD issues?,havent replaced one of these yet,hmmm,might use ground-wrist strap for these if it is an issue
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • splitcrete
        • Dec 2012
        • 387
        • usa
        Pin 1 -22
        1--15.39
        2--14.11
        3--14.11
        4--14.08
        5--13.69
        6--13.25
        7--13.03
        8--12.93
        9--12.92
        10--12.92
        11--11.89
        12--05.04
        13--2.336
        14--2.334
        15--2.320
        16--2.313
        17--2.291
        18--2.187
        19--2.184
        20--1.384
        21--1.344
        22--255.8 mv
        7--
          definitely bad.
          • splitcrete
            • Dec 2012
            • 387
            • usa
            I changed the same IC on a Sony KDL-40SL140 T-con, and that TV is great now. It had a solarized picture as well.
            • splitcrete
              • Dec 2012
              • 387
              • usa
              #26
              Could the chip have been shorted by the person that packed it. I use a ground strap...
              Here I go again I will let you know how I make out. Thank You
              • splitcrete
                • Dec 2012
                • 387
                • usa
                #27
                Changed the IC again, and still the same volts ,and picture. I must have gotten two bad chips . Going to order new chip from a different supplier.
                • Shinju
                  • Mar 2014
                  • 1239
                  I got a samsung ln37a550p3fxza that has a bad T-con, I tried the panel options in tune service menu while it changed the picture the solarized image stayed. I even tried the PDP,JEATA,VESA And again while it made changes the picture remained solarized so I assume it's the AS15 chip?
                  The longer it stayed on the image became more washed out, image retention and ghosting.
                  I am not a SMD soldier by any means if anyone is state side and would be willing to do the fix (yes I will pay!) I would be forever grateful! Otherwise I will just hold out for a cheap replacement!
                  Please drop me a pm if interested in a little cash for your time!
                  • splitcrete
                    • Dec 2012
                    • 387
                    • usa
                    #29
                    Shinju what State are you from ?
                    • Shinju
                      • Mar 2014
                      • 1239
                      Splitcrete, I am in Washington State.
                      • splitcrete
                        • Dec 2012
                        • 387
                        • usa
                        #31
                        Its not to hard to change that IC watch some youtube videos then practice on an old board. Do not try to force the chip off if it starts to lift wait till the whole chip is loose. If you don't you will lift and maybe destroy the pads the chip solders to. Don't over heat the board that will lift the pad also. Take Your Time no awards will be given to the fastest chip change. Good Luck
                        • Shinju
                          • Mar 2014
                          • 1239
                          I might give it a shot, I just don't have the steadiest of hands anymore!
                            If you can get the chip off without damaging the board (all the solder pads silver, be very careful not to tear them as you can't connect the chip without them) then you can put it on. Getting it back on is easy enough. Can you borrow someone's good soldering iron? I wouldn't recommend a $10 radioshack iron, for example. You need something that has temperature regulation. Then a bit of (ideally leaded; lead-free is hard enough to work with as an experienced solderer...!) solder and a bit of solder wick.
                            Alternatively, browse your local Craigslist for the same model with a bad screen. Pay max $25 IMO. (Confirm the picture did not have colour issues before screen broken - hopefully you can see part of the image.) Then swap the T-con boards over. You can then sell the rest and make back your $25.
                            • Shinju
                              • Mar 2014
                              • 1239
                              I been looking on local CL, seems our market is flooded with I WILL BUY YOUR BROKEN FLAT SCREEN diy guys. I don't see a lot and when I do they are gone before I can even get a response.
                              I might hit up a couple of those guys and see if they have any spare parts on hand. I have a deal worked out with a few of our local big chain thrift stores I get first pick on any Panel that comes in not working as long as the screen isn't cracked I take em. So far I am 10/14 and 3 being plasma and one LCD that is un repairable.
                              Thanks for the input tom I appreciate it!
                              • Shinju
                                • Mar 2014
                                • 1239
                                My Sammy was fixed by capkid doing the AS-15f chip transplant.
                                Working great now!
                                • audiofreak19
                                  • Apr 2013
                                  • 556
                                  • usa
                                  #36
                                  I got a sony with a as15-f. I'm about to order one from China since it's only a 1.80 and free shipping. Only thing that sucks is it takes 2-3 weeks to get here.
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    http://www.ernestos-electronics.com/...ltage-buffers/
                                    get it from here the part is already in the USA for $5.50
                                    • audiofreak19
                                      • Apr 2013
                                      • 556
                                      • usa
                                      #38
                                      Thanks I just ordered it.
                                        Hi ecking, is the ernestos pretty reliable? They seems to have lots of parts, may have to try them out.
                                          Ecking runs/owns/is-related-to it, I believe. I've ordered a FET from him before which came in pretty good time for a US part.
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • netgearnetgear
                                            TCL 43S423 TCON OR PANEL FAULTY???
                                            by netgearnetgear
                                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                            08-20-2025, 06:04 PM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
