Samsung LN37A550P3F with bad Gamma AS15 AUOPTO T-CON
Another one of failed AUOPTO T-CON board with bad GAMMA Vref IC AS15.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: Samsung LN37A550P3F with bad Gamma AS15 AUOPTO T-CON
Did you check gamma curve or just replace IC? You can try the spreadsheet I made which helps determine bad gamma IC for sure.
https://www.badcaps.net/forum/showthread.php?t=35301Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I already installed the new IC, the TV is already donated today. I will keep that spreadheet in the future, but so far all the AUOPTO T-CON that I have replaced the AS15 solved the problem, I did 5 so far, need to get more IC.Never stop learning
It seems to be a common fault, you can almost always see it from the picture. The nearest was one which just had overly contrasted image, I believe same Samsung model but Taiwanese, which is also where AUO panels are from.
I'm a data hoarder, I like numbers and certainty. Unfortunately haven't had a single bad gamma IC myself yet.Last edited by tom66; 02-15-2014, 08:47 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I have this exact same model with the T-CON Gamma IC problem (screen too bright/white). My question is how do I get access to the T-CON board? I've removed the 5 screws holding the metal cover and it's loose, but it won't come free. It looks like the T-CON board is moving with the cover. I didn't want to force it too much for fear of doing any damage to the two connectors on the other end of the board. Can someone tell what I'm doing wrong?
I was hoping to take some voltage measurements to confirm the bad Gamma IC (I downloaded the spreadsheet) before sending it off to get repaired.
Thanks.Comment
There's sometimes a thermal pad which is lightly glued to the case. You just need to lever it slightly, maybe best to remove board completely from set.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The above works, seat the whole thing properly, there's sometimes some lugs to hold the T-con in place, gently hold it down where the LVDS cable enters and twist clockwise then anticlockwise, after a few turns it should come free, just make sure the T-con board can't move, a little bit of heat from a hair dryer can help here.Comment
Thanks for all the suggestions. I used a small screwdriver and a little force and the cover popped free. It took a little more dis-assembly to remove the cover, but I eventually got it out. I took the VGMA voltage measurements and tried the above spreadsheet. I think the gamma IC is bad, but a number of the cells in the spreadsheet didn't translate over when using Microsoft Excel.
One more question on removing the T-CON board, how do the two ribbon cables that go to the screen connect to the board? Do they push in from the side or the top of the board? It wasn't obvious to me and I don't want to do any damage when disconnecting.
Thanks.Comment
Can you try posting your listing of voltages? I developed the spreadsheet in OO.org Calc so have not been able to fully test it in Excel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
@marcmum:"One more question on removing the T-CON board, how do the two ribbon cables that go to the screen connect to the board? Do they push in from the side or the top of the board? It wasn't obvious to me and I don't want to do any damage when disconnecting." The brown plastic bar flips up to release the cable, see picture #6 you can see the right one is flipped up. One thing is that it not very easy inserting those two flat cables back in place.Never stop learning
Here are my T-CON Voltage Measurements:
VGMA1: 15.4
VGMA2: 15.33
VGMA3: 15.18
VGMA4: 12.34
VGMA5: 11.54
VGMA6: 10.59
VGMA7: 10.05
VGMA8: 9.79
VGMA9: 8.27
VGMA10: 7.92
VGMA11: 7.88
VGMA12: 0.206
VGMA13: 0.206
VGMA14: 0.206
VGMA15: 0.214
VGMA16: 0.224
VGMA17: 0.244
VGMA18: 0.251
VGMA19: 0.257
VGMA20: 0.291
VGMA21: 0.292
VGMA22: 0.297
VCOM: 6.37
AVDD: 15.61
VGH: 17.3 mV AC (out of limits on DC)
VGL: 16.2 mV AC (out of limits on DC)Comment
I've never seen half of the readings at near zero, wow. Double check those last readings but if so, the gamma IC is definitely bad.
For VGH/VGL, generally not an issue on these, but you might have to use next highest DC range.Last edited by tom66; 02-25-2014, 01:34 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
What are the readings supposed to be for 12-22 my meter is on auto and I'm getting almost the same readings.Comment
Either slow increase our decrease. But it has to be consistent. Ie only increasing or only decreasing.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Pin one was 15.09 and slowly went down till it got to pin 13 and it dropped to 2.336 and went down from there a little at a time pin 22 000.1Comment
The full readings would help.
Soldering looks OK.
Tibimaki replaced IC, and found new IC to be bad. So do not rule out chance you got a bad IC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
			by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
			by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
			by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
			Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
			by Daren87Hello everyone,
I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the... - Loading...
