philips 47pfl6158k/12 image faded away, sound still coming from TV
  • Kartowl
    • Apr 2024
    • 4
    Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
Name:	WhatsApp Bild 2024-04-22 um 21.04.21_00336065.jpg
  • Diah
    • Feb 2013
    • 6562
    try first with firmware upgrade_loader ,use USB stick fat 32 MBR mode... very important MBR mode
    • Kartowl
      • Apr 2024
      • 4
      I cant tell if it does anything, the LED on my USB stick is certanly not blinking, just at the beginning when the tv turns on, it is correctyl formated to fat32 in MBR mode, but the stripes on the tv do get wider over time, I really hope its just the tcon board and not the panel itself :/
      • Diah
        • Feb 2013
        • 6562
        read here how to downgrade upgrade android Philips
        • dadio
          • Oct 2013
          • 7
          • Ireland
          I had two Philips today. One had similar symptoms to yours. I recovered the picture by blocking pins 3 to 14 on the left hand ribbon with a piece of Sellotape 7mm wide.
          The second one had lines appearing across the picture and the same method cured that one too.
          • Kartowl
            • Apr 2024
            • 4
            hey, thanks for the suggestions, I got a new Tcon board and now the TV works fine, but I have a annoying audio delay...
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4538
              • Italy - Milan
              I'm not sure your problem was tcon, that series has common problems at the processor solder joints, try to heat a bit the cpu and see if more problems comes..
              • William1967
                • Nov 2017
                • 217
                • Netherlands
                Additional information: Standard this tv is not an Android, that upgrade_loader only works when there is an upgraded mainboard inside. The original mainboard has a white ceramic cooling block, the upgaded verion has a metal cooling block
                • Diah
                  • Feb 2013
                  • 6562
                  yes this true... but all home normal user never upgrade the MB
                  • alro7779
                    Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                    by alro7779
                    Hello there!
                    Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                    08-07-2025, 11:53 AM
                  • tuner2000i
                    Philips 65PUS8518/12 distorted image after main board replacement
                    by tuner2000i
                    hello everyone,
                    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                    07-15-2025, 01:15 PM
                  • malekservis
                    Philips 58PUS8536/12 Backlight ok, no image
                    by malekservis
                    the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                    Any information would be appreciated....
                    08-07-2024, 07:48 AM
                  • kca
                    Samsung UN48JU6700F (Curved) blotchy and faded image
                    by kca
                    I'm wondering if this type of display error (please see photos) can be fixed by replacing the LED strips or would that be an exercise in futility because the panel has been permanently altered.
                    Notes: It turns on every time. Sound is good too. I have tried changing all the display settings, power cycling it, and resetting it to factory mode. Even went into the Service Menu but nothing worked to resolve these blotchy and faded images. Blotches do not move. The degree of image fade (dimness) always stays the same. Picked this tv up for free so I have no insight into if it was handled...
                    09-19-2024, 12:20 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
