where to buy fuse resistor 0.1ohm1J6
  • ari2009
    • Jan 2014
    • 5
    • us
    Hello I am trying to repair a power supply board.
    where can I get this fuse resistor 0.1 ohm 1J6
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: where to buy fuse resistor 0.1ohm1J6
    http://www.newark.com/vishay-bc-comp...m-5/dp/26R4057
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • selldoor
      Slow Learner
      • 7870
      That link is for .01 ohms resistor? not 0.1 ohm
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        shit i need glasses
        • selldoor
          Slow Learner
          • 7870
          Perhaps a picture of it would help - what wattage is it and what sort of voltage does it have to carry - what does 1J6 mean( is that 1.6joules ?)
          What physical size is it?
          • Ltank
            • Jun 2013
            • 776
            http://rapidtables.com/calc/electric...Calculator.htm
            a joules to watts calc. problem it requires a time to calc.
            if time was 1sec wattage is 1.6 watt, if time was .5 wattage is 3.2watts
            Hope it helps
            • selldoor
              Slow Learner
              • 7870
              Hope it helps
              Hi - Thanks - I had read that during my search - it was only when I didnt find anything I wondered if it was 1.6J ( similar to 1R6 being 1.6 ohms) and only unit I could come up with was Joules .
              I dont think it will be that which is why I am hoping the OP will tell where he got it?
              • ivtec
                • Dec 2008
                • 1967
                Hi Selldoor i bought from Mouser .1ohm resistor fuses and they've sent me these. still have them
                • ivtec
                  • Dec 2008
                  • 1967
                  https://www.badcaps.net/forum/showthread.php?t=33555
                  https://www.badcaps.net/forum/attach...7&d=1386367939
                  • selldoor
                    Slow Learner
                    • 7870
                    Hi - still no idea what those are!
                    I think he wants something like this FKN200JR-73-0R1
                    available from digikey
                    http://www.digikey.com/product-detai...MCT-ND/2813098
                    But till the OP comes back with more info I dont know
                    • ari2009
                      • Jan 2014
                      • 5
                      • us
                      where to buy fuse resistor 0.1ohm1J6--Photo and size
                      Thank you all for you help.
                      the size is 1/2 inch x 1/4 inch x 1/4 inch
                      see the photo, PIP is enlarged.
                      Could I use regular 0.1 ohm to replace it?
                      It is in a Sony 55EX610 LCD TV APS-299 power supply board.
                      part number R6540
                      I read someone in this form replace it but he did not say where to get.
                      Thanks again
                        You can use this one:
                        http://www.mouser.com/ProductDetail/...vDYlHVHIbYE%3d
                        • selldoor
                          Slow Learner
                          • 7870
                          There is some detail here
                          http://www.tvserviceparts.com/.1OHM12WFUSE.html
                          You should try and check the pads for shorts
                          They are a bit expensive to have it blow again
                          Sony number seems to be 1-202-933-61
                          EDIT Budm's are a bit cheaper!!!!!!!!!
                          • ari2009
                            • Jan 2014
                            • 5
                            • us
                            Thank you!
                            I ordered already. I replaced dps-78 board which may caused this fusible resistor blown
                            • magneh
                              Is this some kind of fuse resistor ?
                              by magneh
                              Hello guys
                              Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                              Seem to me like some kind of fuse resistor?
                              After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                              They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                              The red band is larger than the 4 others, but I dont have much experience with these components.
                              Also one of the orange...
                              02-10-2025, 07:54 AM
                            • Babbar
                              by Babbar
                              04-12-2024, 01:12 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • corrize
                              Replacing resistor fuse in Sony DV charger
                              by corrize
                              Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                              So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                              It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                              06-30-2025, 06:59 PM
