Sony Fusivel resistor ?
  • corrize
    Replacing resistor fuse in Sony DV charger
    by corrize
    Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
    So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
    It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
    06-30-2025, 06:59 PM
  • x_orange90_x
    Sony Bravia KD-50X690E blown resistor
    by x_orange90_x
    I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
    The power supply is 715G8413-P01-001-0H2S...
    07-16-2024, 06:53 AM
  • jinu_j
    Dell 2209WA - power supply - Fusible Resistor replacement
    by jinu_j
    Hi
    I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
    1. FR950 - blown fusible resistor - 0.2 Ohm 1W
    2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
    3. R835 - Blown Resistor - 20KOhm SMD resistor
    4. D930 - Shorted Schottkey Diode...
    05-03-2025, 10:51 PM
  • mikey5791
    Need help to replace burned resistor in 350w atx psu
    by mikey5791
    Hi to all forum members,
    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
    12-26-2024, 04:55 AM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
