Samsung LE32R88BD Power Fault
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    have above mentioned tv standby light on but when i try to switch on using buttons at front tv doesnt respond, use remote to turn on, standby light goes off but nothing else happens, no backlight, picture etc.. anyone had same problem ?
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung LE32R88BD Power Fault
    Picture of the set with the back off then good clear pictures of each board
    and close up of the connectors so we can see the labelling often helps.
    Have you tried to find a service manual.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      does this help selldoor
      • Hombre
        • Jul 2013
        • 231
        • Croatia
        There are some burn marks between big primary cap and resistor (i think is rm801), i think that there is small cap under that glue but not sure
          You MUST remove all those Glue.
          https://www.badcaps.net/forum/showthread.php?t=34692
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            what will i do after i remove all the glue ?
              Check for any damage to components due to conductive glue. If there is damage, you might need to replace some parts.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                ok started removing the glue near the big cap , number on the board CM810 where it looks burnt out and one of the legs where broken, looks burnt.. thats possible problem, unsure of what the component is though
                  BN44-###### number of PSU?
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    Bn4400155a
                      See here:
                      CM810: 2.2nF/1kV
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        ok thanks tom, not 100% sure how to use those manuals.. what is in place RM801 that looks pretty burnt too at one side. sorry for bein such a noob
                          0.22 ohm 1W resistor.
                          You can press CTRL+F and type your search key e.g. RM801 and it will find that component.
                          Schematic symbols are simple once you know the basics: http://highfields-arc.co.uk/construc...es/passive.jpg
                          Schematics, like the one linked, show how circuit components come together to form a functioning unit, in this instance, a power supply.
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            thanks tom, i will have a read up and get those components and try them out and get back to you.
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              Tom66 does the CM810: 2.2nF/1kV have to be soldered in a specific way like the Caps or can it go in any way ?
                                It is non-polar, which means it can go either way around.
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  ok Tom thanks
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    Tom66 changed those 2 components oon the board and the tv is working great, thanks
                                      Glad to hear, enjoy the TV.
                                      • Espartaco Smith
                                        TV Samsung UE40MU6405U, not standby (after power failure)
                                        by Espartaco Smith
                                        Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
                                        After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
                                        The power supply is: L40E6_KSM (BN44-00875A)
                                        The main board: BN41-02568B
                                        The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
                                        I've also checked the...
                                        12-17-2024, 02:16 AM
                                      • Chris24
                                        Samsung UN58J5190 - Doesn't Power on and has Standby
                                        by Chris24
                                        Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
                                        Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
                                        I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
                                        I tested with T-Con disconnected...
                                        10-12-2021, 12:43 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • nathan425
                                        Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                                        by nathan425
                                        Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                                        Symptoms:
                                        • - no power
                                        • - no standby LED
                                        What I've done so far:
                                        - confirmed power supply is OK
                                        -- CN201 #4 showing 5.3V
                                        -- BD207 showing 5.3V
                                        -- removing the cable between the main board and the power board turns on the backlight.
                                        Pushing the power button on results in no change to any of the pins connecting the two boards.
                                        - function assembly appears to be NO GOOD
                                        -- there is no voltage showing on any of...
                                        11-01-2023, 06:34 PM
                                      • amennone
                                        Samsung UE50NU7090U , no power , no led standby
                                        by amennone
                                        By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
                                        The power LED remains off, always.
                                        Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
                                        The situation remained the same​
                                        https://**************/dump/lcd_pdp_...oogle_vignette...
                                        11-17-2024, 04:28 PM
