Samsung UE50NU7090U , no power , no led standby
  • amennone
    • Feb 2015
    • 63
    • italy
    By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
    The power LED remains off, always.
    Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
    The situation remained the same​
    https://**************/dump/lcd_pdp_...oogle_vignette
  • amennone
    • Feb 2015
    • 63
    • italy
    Samsung UE50NU7090U
    UHD TV - 7 Series
    BN96-46823A
    CY-NN050HGNV6H​
    • EazyBone
      • Jun 2023
      • 1360
      • United states
      I have 3 of these I can't figure out. Hope you can get som answers.. same symptoms on all of them like you.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4516
        • Italy - Milan
        Excuse me, did you received my private message on Italian forum? Did you disconnected led lights and watched power led and screen with torch?
        • Diah
          • Feb 2013
          • 6497
          i don't think you opened threat on one of them... 3in1 boards for samsung... first things the socket which it go to LED front and wifi./BT we check if there 1.7V for front LED and 5V for wifi.. some model from this series have separated socket
          • EazyBone
            • Jun 2023
            • 1360
            • United states
            Your right I don't think I did. Maybe I'll bust them out shortly and open a thread. I at least narrowed it down to something on the hot side.. the octocouplers had voltage fluctuation or something. After I get a little time I'll bust em out. These boards are like $150 on eBay so you know they have a high failure rate.
            Good call! Open soon
            • Storyteller12
              • Jun 2020
              • 625
              I have 3 of these TVs also with same problem. Just to note I had 1 working board and tried to swap ic from good board to bad one and it didn’t work.
              After switching ic’s back to original boards the good board no longer worked and had same symptom.( no standby light and no power). So make sure if you order a new board you get the correct one.
              keep us posted
              • Storyteller12
                • Jun 2020
                • 625
                There is a winbond ic on the panel buffer board. Have you tried reprogramming that one?
                Also you may want to post your original ic files here and see if Lotas can look at them and see if they’re good. If they are bad he can fix them. Sometimes downloaded ones from the net will not work. Doesn’t have the right info on them for your panel/ tcon
                • amennone
                  • Feb 2015
                  • 63
                  • italy
                  Dump
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
                  • Espartaco Smith
                    TV Samsung UE40MU6405U, not standby (after power failure)
                    by Espartaco Smith
                    Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
                    After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
                    The power supply is: L40E6_KSM (BN44-00875A)
                    The main board: BN41-02568B
                    The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
                    I've also checked the...
                    12-17-2024, 02:16 AM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Chris24
                    Samsung UN58J5190 - Doesn't Power on and has Standby
                    by Chris24
                    Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
                    Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
                    I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
                    I tested with T-Con disconnected...
                    10-12-2021, 12:43 PM
                  • nathan425
                    Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                    by nathan425
                    Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                    Symptoms:
                    • - no power
                    • - no standby LED
                    What I've done so far:
                    - confirmed power supply is OK
                    -- CN201 #4 showing 5.3V
                    -- BD207 showing 5.3V
                    -- removing the cable between the main board and the power board turns on the backlight.
                    Pushing the power button on results in no change to any of the pins connecting the two boards.
                    - function assembly appears to be NO GOOD
                    -- there is no voltage showing on any of...
                    11-01-2023, 06:34 PM
