What bad glue can do to the board
Got 6 Samsung 245bw in, 3 were fixed by just removing bad glue, other 3 are badly damaged (will have to do more repair later).Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None -
Re: What bad glue can do to the board
I have dealt with this glue problem since the 70's. They get old, turns dark brown then becomes conductive and corrosive.Attached FilesNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Does anyone know what kind of insulation adhesive Antec uses in their Delta-built PSUs, specifically the Earthwatt D's? It's like a very dense closed cell foam. Also, what do you use for adhesive? Is RTV silicone safe to use?Comment
I use electronics grade Silicone RTV, regular Silicone RTV is corrosive due to acid content.
http://www.amazon.com/Clear-Electron.../dp/B0063U2RT8
http://www.hmcelectronics.com/produc...licones/RTV162Never stop learning
Do you think Tetrachloroethylene-based silicone will work as well as the artificially high-priced "electronics" branded stuff?Comment
There is no issue with the glue it self, the one who placed it over the PCB he added too much, and caused a violation regarding the Creepage distance in a HV circuitry.Comment
That's absurd... Conformal coating covers the entire board. The problem lies in the conductivity of the glue, not in "creepage distance".Comment
Follow the white rabbit.Comment
I have dealt with this problem since the 70's (some of you were not even born yet, or not getting into electronics yet), it is the chemical in the glue being used, some Chinese companies still use this glue. If you have lots of experience, you will know why it has nothing to do with creepage and clearance. I also use conformer coating in my board design that are used in high moisture location. I also use potting compound on the whole board. BTW, our lab is UL and CSA certified for safety testing. Done lots of HI-POT test @> 3000V.
If the glue is not conductive, you actually increase the creepage distance.
PAGE 1-8.
But what do I know, I am just a kid playing on the keyboard:
https://www.badcaps.net/forum/showth...dge+tom&page=2
budm when you will update your ID from Knowledge Seeker to a Pro ( in 10 years) ,
then I will take you more seriously, for now you are just a kid playing with it keyboard.
By my opinion you do not own even half than the understanding of Tom regarding electronics.
From the other hand Tom goes by the book due his limited experiences which he will improve in time,
those additional experiences they will help him to improvise too by using the limits of hardware with out causing a disaster.Last edited by budm; 01-23-2014, 09:29 PM.Never stop learning
I think that the nerdy Greek strikes your PRIDE for another one time.
Yes it is PAINFUL for anonymous in forum heroes to accept the fact that they are not that smart.
And before some one even think to extend his bitching attempts, he must post first his own qualification degree scanned at 100% as is when it hands on his wall.Comment
Kiriakos - in this case, YOU were wrong... You incorrectly stated that adding too much stabilizing adhesive violates established rules pertaining to maintaining adequate creepage distance... budm correctly pointed out to you that not only were you wrong, but that to the contrary, high-quality adhesive enhances the quality of creepage distance.Comment
I am not bitching, when I want a good laugh, I just read that post, some one else also laughing along when they read it.
"Yes it is PAINFUL for anonymous in forum heroes to accept the fact that they are not that smart" Not that smart eh? And you are SO SMART!
We already see how much you know about safety and creepage and clearance after working all these years and called yourself a pro.Last edited by budm; 01-24-2014, 12:07 AM.Never stop learning
And before some one even think to extend his bitching attempts, he must post first his own qualification degree scanned at 100% as is when it hands on his wall.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Hi gootron, we are not that smart! You also notice that he changed the subject because he does not know how the glues are used and probably never herd of or use electronics grade Silicone RTV.Last edited by budm; 01-24-2014, 12:29 AM.Never stop learning
How about Star Brite Liquid Electrical Tape?My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
I just never use glue. There's really no need to IMO. The soldering is more than enough to hold the components in place (at least on the average TV/Monitor/PC PSU PCB).I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I don't agree... If soldering itself was enough to prevent cold joints due to oscillations, then it would never have been used in the first place... I'm aware that the adhesive is also used to keep components in place during flow soldering, but its main purpose is for high-frequency vibration absorption.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... - Loading...
- No more items.
