Samsung UN58J5190 - Doesn't Power on and has Standby
  • Chris24
    • Feb 2014
    • 42
    Hey everyone - I have a Samsung UN58J5190 with these symptoms: Does not power on, has standby light, standby light blinks 5 times after pressing "power on." When plugged in the power supply is making a very faint ticking sound, and this goes away when pressing power on.
    Following instructions from the great team here in recent posts for Samsung with similar symptoms, I did the following tests:
    I tested with mainboard disconnected from power supply - backlights do not come on (symptoms no change/5 red blinks)
    I tested with T-Con disconnected from one side at at time, and completely from MB (all separately) and backlights do not come on (symptoms no change/5 red blinks)
    Multimeter:
    Power Supply to Main Board:
    Plugged in and power off > to power on:
    A13V 1 : 11.6 > 12.8
    A13V 3 : 11.6 > 12.8
    A13V 5 : 11.6 > 12.8
    A13V 7 : 11.6 > 12.8
    GND 9 : 0.0
    OD-UD 2 : 2.31 > 2.31
    BLU-PWM 4 : 3.26 > 3.26
    PWR ON/OFF 6 : 3.90 > 3.90
    GND 8 : 0.0
    GND 10 : 0.0
    Power Supply to LED
    plugged in to > press power on:
    9 D2-: 00.1>0.36
    8 D2-: 00.1>0.34
    7 NC:
    6 S+: 00.1 > 00.1
    5 NC:
    4 S-: 00.1 > 00.1
    3 NC
    2 D1+: 188.6 > 324~344~352 (repeating back to 324 and up to 352)
    1 D1+: 188.6 > 323~348~354 (also repeating)
    Pics to follow and as always - appreciate the help
  • Chris24
    • Feb 2014
    • 42
    Re: Samsung UN58J5190 - Doesn't Power on and has Standby
    Pics attached - I hope its not another backlight....
    • neilc6
      • Nov 2015
      • 1550
      This model likely has the same failures as UN58H5202AF, bad backlights that damage your power supply. On the UN58H502, one FET typically shorts. Until you test and replace your backlights, you can't start troubleshooting the power supply. Would check the FETs and diodes in the backlight driver section for shorts.
      https://techhometravel.com/un58h5202...oesnt-turn-on/
      • Storyteller12
        • Jun 2020
        • 625
        +1
        Originally posted by neilc6
        this model likely has the same failures as un58h5202af, bad backlights that damage your power supply. On the un58h502, one fet typically shorts. Until you test and replace your backlights, you can't start troubleshooting the power supply. Would check the fets and diodes in the backlight driver section for shorts.
        • Chris24
          • Feb 2014
          • 42
          Thanks guys, I’ll test out the LED driver side and the LEDs next. Appreciate the video - although I am getting power where he was not, I will look for a short elsewhere.
          Would you rule out or have tips to check the MB?
          • neilc6
            • Nov 2015
            • 1550
            The main board sends two signals to control the backlights. A logic BL-ON signal to turn them on and a PWM signal to dim them. Samsungs have pull up resistors on the BL-ON and PS-ON signals so when you unplug the cable to the main board, it forces the power supply and backlight on. If you don't have backlights, you need to resolve that issue first.
            • Chris24
              • Feb 2014
              • 42
              Thanks Neil - that makes sense. I didn't find any bad FETs or Diodes on the PS LED driver area or elsewhere, however with the LED tester I only got ~95V on one side (42 lights) of the LED wire and no response from the other side (or 302V my tester max). Ordered a new set of lights and will take her apart. Will report what I find out. Thanks
              • neilc6
                • Nov 2015
                • 1550
                It looks like one string failed open circuit which will act like a fuse and may have protected the power supply. With your LED tester, you can power the one good string independent of the power supply and turn on the TV to see if you have video.
                • Chris24
                  • Feb 2014
                  • 42
                  Opened her up and multiple LEDs are out, including one complete set. New sets came in from eBay and replaced all the strands and now the TV works. Turned down the backlights immediately 😀 Glad the power supply was protected.
                  Thanks for the help and feedback Neil, and the link to the video which I used to to confirm your points and test/fix the TV.
                  • Espartaco Smith
                    TV Samsung UE40MU6405U, not standby (after power failure)
                    by Espartaco Smith
                    Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
                    After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
                    The power supply is: L40E6_KSM (BN44-00875A)
                    The main board: BN41-02568B
                    The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
                    I've also checked the...
                    12-17-2024, 02:16 AM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • nathan425
                    Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                    by nathan425
                    Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                    Symptoms:
                    • - no power
                    • - no standby LED
                    What I've done so far:
                    - confirmed power supply is OK
                    -- CN201 #4 showing 5.3V
                    -- BD207 showing 5.3V
                    -- removing the cable between the main board and the power board turns on the backlight.
                    Pushing the power button on results in no change to any of the pins connecting the two boards.
                    - function assembly appears to be NO GOOD
                    -- there is no voltage showing on any of...
                    11-01-2023, 06:34 PM
                  • amennone
                    Samsung UE50NU7090U , no power , no led standby
                    by amennone
                    By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
                    The power LED remains off, always.
                    Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
                    The situation remained the same​
                    https://**************/dump/lcd_pdp_...oogle_vignette...
                    11-17-2024, 04:28 PM
                  • riparo
                    tv samsung ue50nu7400 no power led standby
                    by riparo
                    Hi everyone, I have a problem with a Samsung TV model UE50NU7400, I don't have the stanby LED, on the power supply board after a first check I found the fuse blown, and the 2 KF7N50 transistors on the primary power supply both short circuited, I replaced the fuse and the 2 transistors, now the short circuit has disappeared but I still don't have the LED off, do you have any suggestions?​...
                    05-09-2024, 02:17 AM
