Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
  • nathan425
    • Nov 2023
    Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
    Symptoms:
    • - no power
    • - no standby LED
    What I've done so far:
    - confirmed power supply is OK
    -- CN201 #4 showing 5.3V
    -- BD207 showing 5.3V
    -- removing the cable between the main board and the power board turns on the backlight.
    Pushing the power button on results in no change to any of the pins connecting the two boards.
    - function assembly appears to be NO GOOD
    -- there is no voltage showing on any of the command pins. the diagnostic manual states that all pins should read 3.3V before commands.
    -- if I turn my DMM to resistance mode, i can get the LED to light up when placing the probes on both ends of the LED.
    My question is how can I verify whether it's the function joystick or the cabling that is the problem? Some of the part numbers online include the cabling but my unit is combined with the WiFi module on the bottom row which is not included in the parts online. Is there a way to jump-start the boards and tricking them into thinking a power on signal has been sent?
    The troubleshooting workflow doesn't include checking the function assembly as part of the diagnostic so it's not clear if this is the solution.
  • karthur
    • Nov 2015
    • 150
    Re: Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
    Nathan,
    You mentioned you have a service manual for your TV. I have a UN60EH6000 I am trying to get going. Thought that maybe that service manual you have also covers my set. Could you send it to me?
    • Espartaco Smith
      TV Samsung UE40MU6405U, not standby (after power failure)
      by Espartaco Smith
      Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
      After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
      The power supply is: L40E6_KSM (BN44-00875A)
      The main board: BN41-02568B
      The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
      I've also checked the...
      12-17-2024, 02:16 AM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • amennone
      Samsung UE50NU7090U , no power , no led standby
      by amennone
      By inserting power, on the diodes DM856...Dm859, there are 9 volts, when you press the power button the voltage is 12 volts, voltage present for a few seconds, then returns to 9 volts
      The power LED remains off, always.
      Reprogrammed Ic 503 = 25Q40 and IC 501 = 25Q80, downloaded from the site
      The situation remained the same​
      https://**************/dump/lcd_pdp_...oogle_vignette...
      11-17-2024, 04:28 PM
    • riparo
      tv samsung ue50nu7400 no power led standby
      by riparo
      Hi everyone, I have a problem with a Samsung TV model UE50NU7400, I don't have the stanby LED, on the power supply board after a first check I found the fuse blown, and the 2 KF7N50 transistors on the primary power supply both short circuited, I replaced the fuse and the 2 transistors, now the short circuit has disappeared but I still don't have the LED off, do you have any suggestions?​...
      05-09-2024, 02:17 AM
    • ojoil
      Samsung UN55MU7000F No Power No Standby LED
      by ojoil
      I read through this post:
      https://www.badcaps.net/forum/troubl...no-power/page2
      It seems like my tv is exhibiting similar symptoms. I have backlight when only the power supply is connected, but I didn't test much further.
      The main board is slightly different (BN94-12402R) although it is stamped the exact same...
      Board is stamped:
      MODEL: KANT_M_BUILT_IN
      CODE: BN41-02568B
      MODEL: BN41-02568
      I wonder if flashing...
      04-30-2024, 09:06 PM
