Vizio E322Ar Picture Problem
    Re: Vizio E322Ar Picture Problem
    Panel looks OK, that does not look like typical panel fault. I suspect that big processor under the heatsink - probably another soldering failure..... oh, so so common these days.
    • johnpeg
      • 22
      Can that be fixed?
      Or should I replace the board?
      • johnpeg
        • 22
        Has anyone ever fixed on of these?
        The heatsink is NOT bolted on, it's soldered on.
        • selldoor
          Slow Learner
          • 7870
          I think the chances of fixing it are slim, without specialised equipment.
          New board is probably the way forward.
          You could try a risky reflow with a heat gun but even if it worked it is unlikely to last.
          • johnpeg
            • 22
            Thank you for your response.
            The board I was looking at sold. The other one is $90. It seems like a hard board to get for a 32 inch. Tons of them for a 42 inch. They are the same board, the only difference is where the cable plugs in that goes to the panel.
            • smai
              • Dec 2013
              • 69
              there maybe other TVs that use the same board, have you looked at shopjimmy ? they usually will have other compatible tv models listed
              • johnpeg
                • 22
                Yes, I did check shopjimmy they are out of stock. Will keep searching. Thank You for all your help and will keep you informed on what happens when I get the new board.
                • mattress
                  • Aug 2014
                  • 33
                  • US
                  #28
                  Was curious if you ever got a new board. I have same tv with Same problem. Suspected tcon fault, but tcon is in mainboard.
                  Wanted to replace the mainboard. Found this thread.
                  • johnpeg
                    • 22
                    Yes,I found one on ebay and the tv works great now. Good luck they are a hard board to find.
                    • mattress
                      • Aug 2014
                      • 33
                      • US
                      #30
                      Thank you. And yes they seem to be hard to find. Having the same luck as you in finding the boards with the 42" connector instead of the 32" connector.
                      • EGreen
                        • 33
                        I have a problem with a power board on this same TV. The resistor in the picture tests at 000.1 ohm removed from the board. I'm having a hard time identifying the value. I think it's supposed to be 6.8 ohm 1 watt. The body is 10mm x 4mm dia. The color bands are hard for me to decipher. The board is # Vizio 56.04119.071 (AIVP-0089) Power Supply. I would like to get a schematic also . Can anyone help me with this? E
                        The resistor is is pink one in space R602
                        • EGreen
                          • 33
                          The colors on mine are Black,Blue,Silver or Grey?, gold,green
                            You should set you meter to better resolution to read <1 Ohm resistor.
                            You also need to find out what your meter probe resistances are.
                            If the resistor does not not show as open circuit and show <1 Ohm then it is good. Doubt that this resistor is the problem.
                            It is fusible resistor for feed the Q102, 103 MOSFETs for VBL SMPS section.
                            What is this power supply or the TV not doing?
                            • EGreen
                              • 33
                              Thanks for the reply. I will post more info when I get home from work. E
                              • EGreen
                                • 33
                                My skills are limited to testing and replacing components trying to learn as I go. Before I found this forums I removed all the larger caps and diodes and tested,all read good. I removed the mosfets and tested on off with the test leads, all tested good. Removed and checked rectifier and power transistors using diode and resistor settings ,good. I have 168vdc at the rectifier at the output pins I get varying volts between 1.3 and 2.9 vdc. This board took at voltage hit of some kind, probably lightning since this Florida. I started testing the surface mount resistors yesterday and more than half test bad.I have no experience with these type of resistors. Can that many be bad? One will test bad and the one right next to it tests good using the resistance setting and varying ranges to be sure.Am I testing them wrong ?
                                PIC 1 my board back
                                PIC 2 burning spot from voltage spike ?
                                PIC 2 my cheapy meter I got to replace my broken one
                                PIC 4 my board front
                                PIC 5 my board back not blurry (Don't know how to delete and replace pics)
                                • EGreen
                                  • 33
                                  Please excuse my crappy soldering, I'm a better welder than solderer.
                                  • EGreen
                                    • 33
                                    From Budm
                                    No standby light no power
                                    • EGreen
                                      • 33
                                      I learned little more about how to read the codes on these surface mount resistors. With the proper range settings they all test good.
                                      • rajbot
                                        No Power problem with Vizio E60-E3
                                        by rajbot
                                        Hi all:
                                        I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                        I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                        On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                        03-22-2023, 08:09 AM
                                      • maricm
                                        Vizio m65-c1 picture flashing on and off on the screen
                                        by maricm
                                        HI all,
                                        hope someone point to the possible issue before I start buying replacement parts.
                                        Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                        Backlight stays on all the time,
                                        Sound works fine.
                                        screen keeps changing form black to full picture in about 1sec intervals.
                                        Picture looks fine with no visible artifacts.
                                        I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                        Disconnecting left and right ribbons on...
                                        11-25-2023, 06:32 PM
                                      • csmith
                                        Vizio D50u-D1 Powers up no picture
                                        by csmith
                                        I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                        Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                        supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                        issue. Set will power up with remote but not power off....
                                        07-11-2025, 11:52 AM
                                      • doorzon
                                        AOC AGON AG273QCG refresh problem picture shifts
                                        by doorzon
                                        hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                                        The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                                        See attached picture.
                                        I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                                        However, this could also be related...
                                        08-12-2023, 02:36 AM
                                      • Tr0ll
                                        by Tr0ll
                                        Original T-con:
                                        First replacement T-con:
                                        10-07-2023, 07:48 PM
