LG 55EC930V Screen problem
This topic has been answered.
  • Bandsei
    Bandsei
    • Nov 2023
    • 19
    • Danmark
    Hi Diah
    There is a difference
    Collors are right and no black beam
    Bernt
    • Bandsei
      Bandsei
      • Nov 2023
      • 19
      • Danmark
      Hi Davi
      I will try to get a picture of the "inlet" to the screen
        • 12276
        • U.S.
        Originally posted by Topcat
        Kids kids kids..... Take the personal attacks somewhere else....
        So how do they, since the redesign of this site, I don't even see a simple way to pm anyone, which is where disagreements belong, so as not to shit up a thread, correct.
        • Diah
          • Feb 2013
          • 6435
          Originally posted by Bandsei
          Hi Diah
          Bernt
          log in INSTART service menu... and show the option of first page and OLED option.... i think we have now close issue at yours replacement T-CON,,,, also try send INSTOP to make Hard reset
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Click the user's name, to the right of the avatar there's a 'private message' button.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Admin
              • Oct 2003
              • 5334
              • United Kingdom
              #26
              Hi nomoresonys, just to clear this up. There is a PM system and automatic notifications. We subscribe users automatically to posts they contribute (but you can change this setting in the user settings). However, if a user sends an abuse report to our email service provider (instead of simply unsubscribing) that triggers an automatic removal of all messaging options. This is to prevent sanctions on our sending quotas.
              • Bandsei
                Bandsei
                • Nov 2023
                • 19
                • Danmark
                #27
                • Diah
                  • Feb 2013
                  • 6435
                  try to downgrade the firmware to old version... then upgrade it to the last one... after each downgrade and update need to send INSTOP for hard reset... hope your screen come all on in case not be sure the ribbon you play before with them not damaged..... if are fine we still have issue at your replacement t-con
                  • lotas
                    • Jan 2016
                    • 4752
                    • Russia
                    #29
                    On this “ED42D” chassis, matrices are dying all over again, no T-CON or repairs will help here, only replacing the matrix.
                    • Diah
                      • Feb 2013
                      • 6435
                      this is wrong.... take look at first post with original T-CON... what you showed are the ebay replacement one.
                      • lotas
                        • Jan 2016
                        • 4752
                        • Russia
                        #31
                        Here you can identify this if this matrix had “ears” on the outside, that is, tabs, side cofs and on the affected side they could be removed, but on this matrix they are hidden in the glass.
                        And what I showed in the photo is the same malfunction, from the same model and no service center could fix it, everyone says only replacing the matrix.
                        • Diah
                          • Feb 2013
                          • 6435
                          i am person don't believe on other or service center said... much enough OLED i have under hand not only for repair but for QC test and report..
                          yes its curve one had side edge COF. but since original T-CON didn't cut the right side,,, but it had color fault... and the replacement T-CON from eBay... show correct color but cut from the right side.... allot need to tell and test and at low coast to bring back to normal.... so please don't tell users end result while you heard or read some where ells.
                          • lotas
                            • Jan 2016
                            • 4752
                            • Russia
                            #33
                            Okay, let's wait for the result of this repair.
                            • Diah
                              • Feb 2013
                              • 6435
                              it depend not on me or you... its up user and his equipment for traces signal... oscilloscope
                                • 12276
                                • U.S.
                                #35
                                Well I have no message options anywhere, top cat always said if there's a disagreement take it to pm, which is a good rule, doesn't shit up the threads. So because I might have told one of the members to eat crap in a pm, I no longer have a pm option? I don't really care, just trying to figure out whats up.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4460
                                  • Italy - Milan
                                  #36
                                  Hi Bandsei, yes new tcon is better than the original, it surely has no issues.. i suspect both original tcon and the panel T.A.B.s (plural.. i guess them are present..) suffers from oxydizing.. are you in a somkers house? Or doesn't you change air soon after cooking? In some other case could be even farts.. (hehehe, ok it's not your case..)... the goal for me is that you heat with phon or better hot air at maximum temp. around 300C the right problematic side (from the front) on the screen T.A.B.s, make a prolonged heating, better with the screen turned on with the selftest if possible, wathcing realtime any improvements.. if the job works, you can also save original tcon with a deep reflow of entire board..maybe.. but the task is not ended.. lets we see next the other passes to do..
                                  • Admin
                                    • Oct 2003
                                    • 5334
                                    • United Kingdom
                                    #37
                                    I have re-enabled private messaging. Log out and back in and you should see a white speech bubble next to names in topics. Plus Messaging / Message Center in the top menu.
                                      • 12276
                                      • U.S.
                                      #38
                                      Thanks Admin, for the fast efficient resolution, best moderator I have seen here, one guy gave me 4 points that he meant to give to someone else and he didn't even bother to take them off. It's refreshing to see someone who knows what they are doing. I want to ask what's the rule for pm, am I allowed to use some colorful words, never threats of course. Sometimes there's just no substitute for a well placed curse word to relay how you are feeling, or will that bring what you spoke of? Thanks.
                                      • Admin
                                        • Oct 2003
                                        • 5334
                                        • United Kingdom
                                        #39
                                        Common sense rules. Users can't use PM as a tool to criticize, bully, argue, upset, or offend users. You can use colorful language as long as it's not directed at or about a specific user. We can monitor content of PMs but don't unless a specific complaint is made.
                                          • 12276
                                          • U.S.
                                          #40
                                          Got it, Sunday school rules apply, thanks.
                                          • mmccomputer
                                            problem with replacing lcd screen
                                            by mmccomputer
                                            I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                            otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                            If anyone has any information on the subject...
                                            12-15-2024, 03:44 PM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
                                          • alltvrepairs
                                            Lg TCon test pins for screen test
                                            by alltvrepairs
                                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                            Appreciate your help....
                                            06-13-2025, 06:33 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
