Merry Christmas every one.diodes to you
Merry Christmas
Tags: None
Re: Merry Christmas
I am not a Christian, or even religious. It is still Christmas to me. Not Winterval. Or Happy Holidays. The good 'ol holiday with Santa and sleigh.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: Merry Christmas
Merry Christmas to all.Never stop learning
Re: Merry Christmas
Yes Merry Christmas everyone!"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Re: Merry Christmas
Happy Holidays and Merry Christmas!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
by shovenoseHi all,
I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...1 Photo -
by Francesc V.Hi:
i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
Could... -
by JoyoungjaeDear friends
Merry Christmas
I came out to work briefly today as well.
I'm not unhappy haha
I received a MacBook Pro A2442 water damage.
When I connect the charger, it keeps turning on and off and the voltage indicator blinks.
When the charger is removed, the power turns on and remains on with the remaining charge in the battery.
After submersion cleaning, the submerged Q5240 and UG800 (elc180 power ic?) were replaced.
Still, the symptoms are the same, so I'm trying to replace the charging IC, but... -
Hi there all, Merry Christmas and Happy New Year!
Looking for advice, Need to restore/fix the damaged Acer Aspire 514 -54 power circuit pathways.
I am not good at reading schematics and have difficulty finding the board viewer schematic or simple schematic for damaged parts, but I have all the tools and experience for micro-soldering. All I need to figure out is which ends (from-to) and trace wires to restore lines.
Hope the pictureS are clear enough to see the problem...-
by cheeky2Merry Christmas
Does anyone know how to bypass the protection ic OZ9928SN on a LG 47LG5000 inverter using a I470H1-20A MASTER pcb?
Pictures attached
Thanks in advance...12-26-2024, 05:25 AM - Loading...
