Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2152
    #101
    Re: Samsung le46b530p7w
    Ah tom i found the ready option and next to it says failure
      If you press OK when highlighting what does it do?
      • sordids999
        • May 2013
        • 2152
        #103
        It won't let me highlight skips to next one down
          Well I have had a set before which had that option set wrong and it would turn on and off too. But it was full on/off not just backlight.
          Have you checked INV ON/OFF voltageyet? On connector between main and power. If this voltage is not varying, no point chasing main board fault: it's not the main board that's bad.
          • sordids999
            • May 2013
            • 2152
            #105
            No tom struggling to find which one this is sorry
              What are the labels on the pins next to the connector? One should be BL ON, or ON/OFF, or INV ON/OFF, or INV ON, ...
              • sordids999
                • May 2013
                • 2152
                #107
                Pin 1 PS
                Pin2 sync
                Pin3 sb
                Pin4 and
                Pin5 gnd
                Pin6 gnd
                Pin7 13v
                Pin8 13v
                Pin9 gnd
                Pin10 gnd
                Pin11 gnd
                Pin12 gnd
                Pin13 5.1v
                Pin14 5.1v
                Pin15 5.1v
                Pin16 5.1v
                Pin17 gnd
                Pin18 gnd
                Pin19 13v
                Pin20 gnd
                Pin21 13v
                Pin22 13v
                pin 23 inv-on
                Pin24 i-pwm
                Pin25 e-pwm
                Pin26 gnd
                Pin27 5v-set
                Pin28 and
                Pin29 and
                Pin30 gnd
                  INV-ON on yours. Check voltage on this pin (red probe on pin, black on chassis) Does it vary?
                  • sordids999
                    • May 2013
                    • 2152
                    #109
                    4.8-4.9 volts
                      Not dropping out when backlight goes out?
                      • sordids999
                        • May 2013
                        • 2152
                        #111
                        No mate still the same with backlight off
                          OK that means the main board can be eliminated.
                          If you change the backlight setting to a higher level from the user menu does it cut out quicker?
                          • sordids999
                            • May 2013
                            • 2152
                            #113
                            That's the thing now tom the backlight in the menu are set on 10
                            But I'm still having to short out PCI801's everytime I restart the time then it will stay on for ages
                            • sordids999
                              • May 2013
                              • 2152
                              #114
                              The TV has been on most of the evening but backlight goes once u turn it off and on after 2 secs
                                A permanent short across PCI801S does nothing?
                                • sordids999
                                  • May 2013
                                  • 2152
                                  #116
                                  No we tried that remember
                                  • sordids999
                                    • May 2013
                                    • 2152
                                    #117
                                    Been reading up on net was thinking one of the lamps has gone in the panel which would draw more voltage to the invertor board but I read it cuts out the TV completely so it can't be that
                                      A bad bulb could cause this as could arcing between bulb and frame, both could be temperature sensitive. though usually would not be affected by that PCI801S.
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        #119
                                        So main board eliminated new power unit fitted replacement invertor changed lol that just leaves the tcon board unless its a bulb
                                        • sordids999
                                          • May 2013
                                          • 2152
                                          #120
                                          tom if i test these invertor test points im getting about 180 volts on average but when the back light goes i get nothing is that right ?
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • kotel studios
                                            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                            by kotel studios
                                            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                            Yesterday, 02:07 AM
