Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2161
    #61
    Re: Samsung le46b530p7w
    not really ill try that now
    • sordids999
      • May 2013
      • 2161
      #62
      ok tom any more options plan B ?
        yes, can you see the chip LX9503 is it on the bottom or the top of the board?
        • sordids999
          • May 2013
          • 2161
          #64
          on main board ?
            Power board. We will focus on power board for now only, as the problem looks to be independent of the main board.
            • sordids999
              • May 2013
              • 2161
              #66
              do you mean LX6503 if yes then it at the top of the board
                Yes LX6503. Please check pin 7 voltage, red probe on pin 7 black probe on chassis. It should be >2V continuously if backlight on.
                • sordids999
                  • May 2013
                  • 2161
                  #68
                  tom do you mean pin 7 on the psu via the attached picture ?
                    On LX6503 not on the connector sorry for not being clear.
                    • sordids999
                      • May 2013
                      • 2161
                      #70
                      1.3 v tom
                        That seems too low. Does it increase when the TV backlight works? You could solder a wire to that pin to make monitoring it easier.
                        • sordids999
                          • May 2013
                          • 2161
                          #72
                          ok ill try it now
                          • sordids999
                            • May 2013
                            • 2161
                            #73
                            no tom 1.3v and seems consistent and thats with backlight working and not
                            • sordids999
                              • May 2013
                              • 2161
                              #74
                              tom ive sourced another power unit shall i order it and try that one ?
                              i suppose i could always end it back if still not succesfull
                                Yeah, I would try that.
                                • sordids999
                                  • May 2013
                                  • 2161
                                  #76
                                  ok thanks
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    #77
                                    hi guys
                                    just a quick update replacement psu came today installed it still the same so changed the invertor i bought back to my old invertor and the tv seems fine at the moment
                                    1hr and counting
                                    thanks for your help tom
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      #78
                                      6 frigging hours and now it fails i give up
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        #79
                                        would it be worth trying this tom ?
                                          If you checked ON/OFF and it's steady it wouldn't. Sounds like you have a thermal issue. Have you tried heating bits of board up and seeing if you can get it to fail?
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                            by JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                            Please help. Thanks in advance!
                                            08-12-2025, 11:45 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
