Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2161
    Re: Samsung le46b530p7w
    @johnboy yes
    @ tom need to pop out I'll check in a hour then I'll reply thanks
    • sordids999
      • May 2013
      • 2161
      tom when the tv picture goes out i measure the voltage across PCI801's and the backlight comes straight back on
      • sordids999
        • May 2013
        • 2161
        could it be the panel thats failing ?
          The panel would not cause this. I suggest reconnecting JP852 and placing a solder blob between the secondary pins of PCI801 (do not do it on the primary side.)
          • sordids999
            • May 2013
            • 2161
            ok tom ill reconnect jp852 then solder a blob across these connections in the picture ?
            thanks
              Hard for me to tell, which side is primary and which is secondary? The blob goes on the side of JP852.
              • sordids999
                • May 2013
                • 2161
                #27
                does any of these pictures help tom ?
                the first picture shows where jp852 is
                  Blob goes on side of device facing label PCI801S.
                    Looking closer, this set might be using JP854 instead of JP852.
                    • sordids999
                      • May 2013
                      • 2161
                      #30
                      so if im right on this the blob now goes to the top not the bit i highlighted ?
                        The image you posted appears with PCI801S marking facing down. You need to place the blob across the pins closest to PCI801S.
                        • sordids999
                          • May 2013
                          • 2161
                          #32
                          ok thanks
                            If that doesn't work, it may be JP854 on your TV that is the UVLO sense. But I think this will work.
                            • sordids999
                              • May 2013
                              • 2161
                              #34
                              seems to be working ok for now tom thanks
                              • sordids999
                                • May 2013
                                • 2161
                                #35
                                opps spoke to soon lasted 10 mins
                                  OK, remove solder jumper and cut JP854. (JP852 should be connected again.)
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    #37
                                    ok jp852 connected jp854 cut ive removed the blob of solder from PCI801S but the tv turned on then quickly the picture went off again
                                      OK, when the TV is working, what do you measure across PCI801S? What does it do when it fails?
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        #39
                                        109v when picture comes on and fails
                                          1-point-09V? Or 109V?
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                            by JunkmanJimbo
                                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                            Please help. Thanks in advance!
                                            08-12-2025, 11:45 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
