Sony KDL-46EX400 2 blink error code
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46EX400 2 blink error code
    I have checked a couple of those components and they didn't appear bad.
    So no luck with that find. It may help somebody else in the future.
    • tibimakai
      • Jan 2012
      • 3680
      To tell you the truth, I don't know what to do next.
      I can't flip over the board to do those measurements.
      What I'm noticing is that with the old board, the 12V won't stay on as with the one from Ebay. They turn on(except the T-con 12V) and then off.
      The AC_OFF_DET= 2.77V, not getting higher.
      Audio 12V and the Reg_12V they both turn on, but then off.
      • tibimakai
        • Jan 2012
        • 3680
        I have just used a 1k resistor and a 2.2k resitor to boot up the PS and I have backlight.
        The T-con voltages are still missing though.
          T-con volt may or may not be switched by main board.
          • tibimakai
            • Jan 2012
            • 3680
            It has a T_ON pin on the connector.
              The T-ON pin is the receiving pin which gets its ON command from the main board.
              • tibimakai
                • Jan 2012
                • 3680
                What should be the next step?
                It could be something with the Q6151, Q6152, Q6554 area?
                • tibimakai
                  • Jan 2012
                  • 3680
                  Should I try booting up the T_Con_ON with another resistor?
                    You can use the 1k resistor on the T_ON and the STBY voltage to force on the 12v T-CON but you have to disconnect that wire which goes back to the main board because the out put may be stuck in grounded mode. You can see that in the SCH that I had redlined.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      It's disconnected right now.
                      I have a 1K resistor going to the PS_ON and another one to the BL_ON. A third one will go to T-Con_On.
                      I will try it out tomorrow.
                      I guess, if it will turn on, then I have a bad mainboard and if not, then I have an issue at the T_Con 12V stage, am I right?
                      Thanks.
                        If the 12V does not present at the 12v T-CON pin, then that may be the reason for the error code, the service manual keeps mentioning about 12V power supply failure. There is not much in that section of T-CON power supply.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          The other 12Vs turn on, only the T_Con 12V doesn't turn on.
                          I will try it out when I can. Right now my lower back flared up.
                            Q6151 power MOSFET is being used as a switch to supply the T-CON 12V, if you short the E and C of the transistor Q6152, that will turn on the MOSFET Q6151, you can force it on that way also instead of using the 1K to feed the B of Q6152 to turn it on.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I will do that, I don't have another 1K resistor.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have used the 2.2K which I have used to start up the BL.
                                T_CON 12V it shows 12.73V.
                                So the power supply is good, no?
                                I need another main board right(the third one on this TV)?
                                  That means some how the new board also failed to send out the T_ON signal.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    What I don't understand is, why every time I get a "new" board, it works for a while and then doesn't turn on, on an another day?
                                    I update the firmware too, to the latest one available.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      There is a way to reset these mainboards? Clear the error log?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Before I'm going ahead to buy another mainboard, I would like to ask a question.
                                        The 12.73V is not to high to damage something in the mainboard?
                                        It's just weird, that two boards have the same symptom, not counting the original board.
                                          On a 12V rail, that is fine. If it were 15 ~ 20V, damage could occur.
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            Today, 12:53 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Famo
                                            Sony KDL-52Z4500 6 Red LED Blink
                                            by Famo
                                            Hello badcaps forum.
                                            I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
                                            06-09-2023, 10:21 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
