Sony KDL-46EX400 2 blink error code
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46EX400 2 blink error code
    Here is the PDF file:
    • tibimakai
      • Jan 2012
      • 3680
      It can't be, that the mainboard is not giving the signal to start the T_Con?
      • tibimakai
        • Jan 2012
        • 3680
        I think that I was right.
        I ended up removing the PS board and swapping between the two TVs with no change.
        Then I have replaced the mainboard, and the TV it worked as it should.
        So another Sony mainboard Tom.
        Lately I'm just repairing Sonys and Samsungs. I can't find a Vizio anymore.
        For a couple of days I had five Sonys in my house for sale. I still have three and a Samsung.
        Now I need to find another mainboard.
        It seems the the EX class suffers of mainboard issues.
        • tibimakai
          • Jan 2012
          • 3680
          For this board to be compatible with your TV, make sure that you look at all the numbers on the board, but probably the most important is the bar code sticker.
          Mine it was: 55.71S01.C11...(the C11 is important here).
          • tibimakai
            • Jan 2012
            • 3680
            After a while(TV it was sitting in the garage), I have started up the TV and it wouldn't turn on again. It shows the same 2 blinks.
            It has the same BL_Error of 3.3V on all the time. T-Con 12V still missing.
            What could be this, a bad tube?
            • tibimakai
              • Jan 2012
              • 3680
              How it should be showing the BL_Error if everything it's OK?
                Usually LOW, less than 1V.
                • tibimakai
                  • Jan 2012
                  • 3680
                  What should I look for.
                  Transformers look OK. Should I check out the ccfl tubes?
                  I still have the same exact TV which works great.
                  Should I just replace boards?
                  I don't understand what happened here. Put in another main board and it started working and now it's back to the same blinking error?
                    I'd swap balancer + PSU, if same error occurs, swap main board.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have swapped the PS board and didn't change anything.
                      Then, I have changed the main board and the TV started right up.
                      The same exact thing happened last time and then the main board died(not sure about this) after a couple of days. It could be that something else could damage a new main board?
                      I haven't replaced the balancer board yet.
                      I may not have enough time to do that. Today, the other TV it may be sold. Will see.
                      I'm returning the purchased main board and I will get another one as soon as possible.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Got another mainboard and with that, it seems like it's working. Will keep using it for a while, to make sure that is all OK before I sell it.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Today it stopped working, with the same two blink error code.
                          What is going on here?
                          Third mainboard does the same thing. Initially it's working and then brakes down.
                          I haven't done any measurements yet, but I expect the same voltages missing, the T-con board 12V missing and the T-con On is 0V.
                          Any ideas what could cause this if not the mainboard? The T-con may have some issues?
                          I'm wondering, these mainboards are get damaged?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I have measured the voltages and they are the same. All voltages are there, but nothing goes to T-con. No T-con ON and no T-con 12V. BL-Error is 3.3V, that is OK?
                            This one is getting ridiculous. Ebay seller states that I have other issues with my TV and I begin to believe him, since all three main boards show the same exact symptom.
                            What can I test next. What kind of resistor can I use for PS_ON + ST-BY to kick start the PS, 100 Ohm? St_By is 3.3V. I have tried with a 1K, but nothing happened.
                            I would appreciate any help, I'm trying to repair this as soon as possible, because Ebay seller has a 14 days return policy and I have lost already a couple of days with this heat.
                            • kevinm34232
                              • May 2012
                              • 1884
                              Could this be a problem with the AC-DET circuit maybe? Sounds to me like something on the PS board at this point.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Not sure which one is that or what it does. Could you please elaborate a bit?
                                The BL_Error has a 3.3V also, that should be there?
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Tom pointed that out on another one of my TVs, I was missing the voltage on that pin, and he would know more but there is a photocoupler that goes the other way than the others (looks like PH6302 on yours) and your AC_OFF_DET pin is pin2 on the main board connector.
                                  On mine it was missing the 5V, and I had to bridge pins 3 and 4 of the photocoupler which fixed the TV but we weren't sure where the real problem was.
                                  There are also a couple of other ICs on the PS board, Im not sure where the error signal gets generated from though, and if AC_DET would cause a 2 blink code or not.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Did you ever replace PS board? If it helps:
                                    https://www.badcaps.net/forum/showth...t=sony+2+blink
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      On mine I can hear the relay click as I plug the power cable in and then it starts blinking red 2x. Never goes green.
                                      I don't want to replace a power board, I want to repair it. I replace mainboard and T-con only.
                                      It seems that I will have to look for the T-con 12V from where is coming from and do some investigation. I'm in a hurry, because I already exceeded the 14 days return policy on Ebay. The seller is asking his technician and it keeps saying that I have other problem and not the mainboard is the problem.
                                        On the power supply board, are you getting 12DC at both end of the 7A fuse PS6151?
                                        Are you getting 380Vdc on the main filter cap C6516?
                                        What DC voltage measure at the legs of C6206 (it is in the Primary side of the 3.3V power supply HOT section)?
                                          By the way, do you know the chassis number of this TV?
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            07-18-2025, 12:53 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Famo
                                            Sony KDL-52Z4500 6 Red LED Blink
                                            by Famo
                                            Hello badcaps forum.
                                            I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
                                            06-09-2023, 10:21 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
