Dead Olevia 265TFHD-T11
    Re: Dead Olevia 265TFHD-T11
    From the pictures, it has two identical power supply modules, each module supplies the 24V to 3 inverter boards. So do you get 22.7v on the output of BOTH power supplies?
    • HAHOMETP
      • Nov 2012
      • 155
      The TV is about 40 minutes away from me. I'll check that next time I am there. 22.7v is probably a bit on the low side but I doubt that it makes the make it or break it difference. I still do not see any voltage that could tell the inverters to fire up. I have a feeling that this trigger voltage should be present in the white 4-wire harness between the left middle inverter and the T-Con. This white harness is the only connection between the inverters and the rest of the circuit besides the red +24v power harness .
        It can make a difference. I've had inverters that shut down at less than about 23V input. Nominal range is 23V to 26V.
          The LCD panel specification may give us the pinout of the inverter boards and the T-CON board. Can you see the sticker on the LCD panel assembly?
          • HAHOMETP
            • Nov 2012
            • 155
            You both have intrigued me with this new hypotheses. What if indeed the cause of the malfunction is as silly as that one of the PSUs fails to deliver the required voltage? I'll measure the actual 24v voltage on both PSU in both the idle state and under load and report back. Thanks much for the ideas!
              Both power supplies have to be working.
                And usually if one is faulty, or significantly lower the other will pull it up, causing one power supply to take the whole load. If this is the case, then that might explain the drop in output voltage -- though I'd at least expect to see a 2 seconds to black like symptom where the inverter attempted to light up. Perhaps a fault detect fires immediately. I think this is a Sharp panel, and Sharp do have inverter error outputs. I'm assuming both are in parallel. It may be that one drives the master and the other drives the slave instead. Also, verify your multimeter battery!
                  It looks like master/slave setup for this 65" panel.
                  • HAHOMETP
                    • Nov 2012
                    • 155
                    This indeed sounds plausible.
                    I'll check the batteries and also will take at least a couple of multimeters along with me. Besides the trusty American made Wavetek 2030 (4 places after the decimal point) I also keep around a vintage Russian made (1958) analogue multimeter that used to belong to my dad. It's indispensable in catching short spikes of voltage which modern digital multimeters tend to overlook. Maybe it'll help me catch that elusive "nanosecond-to-black" spike of voltage if it there in the first place of course.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Originally posted by HAHOMETP
                      Wavetek 2030
                      Your 2030 has a feature called peak hold which might be quick enough for this test? According to the manual
                      https://cdn.badcaps-static.com/pdfs/...eee71bfdad.pdf
                      Works with AC and DC current and voltage and records inputs as short as 1ms. Select measurement function and apply input to meter before activating PK.
                      --- begin sig file ---
                      --- end sig file ---
                      • HAHOMETP
                        • Nov 2012
                        • 155
                        Yes I am aware of this capability. When I first acquired this multimeter almost 20 years ago I did play with the peak and hold feature but time and again I would inevitably return to the old analogue multimeter for short spike catching and general trend observation. A slight jerk of the analogue pointer is quicker and easier to spot than to first activate the peak and hold mode and then go look for the result. Especially when the actual value is unimportant but the general trend is.
                        • HAHOMETP
                          • Nov 2012
                          • 155
                          I have finally gotten around to testing the PSU's in both idle and loaded states. I have attached the updated picture.
                          Interestingly the same two orange wires that are marked 24VA on the PSU (CN2) are marked +25v on the Main PCB (J55).
                          • Tiezane
                            • Aug 2013
                            • 98
                            I see this is kind of old, but if the two PSUs are identical, did you try swapping them around, and seeing if you get the same results? I see the one PSU has an extra cable connected, the one that is supplying the ~22v, it's possible that maybe just that one portion has issues, and swapping them around may get you some extra life from the TV...
                            • HAHOMETP
                              • Nov 2012
                              • 155
                              Yes, I did try that. No effect.
                              • jmannewitz
                                • Jun 2014
                                were you able to come to a conclusion on how to get the TV active again. I have the exact same TV with the exact same issue.
                                • HAHOMETP
                                  • Nov 2012
                                  • 155
                                  Yes and no. I scored the main PCB off ebay and as soon as I installed it I began to get the faint Olevia start up logo on the screen so that is out of the way. Now I need to find out which of the 6 inverters (or their respective CCFLs) is bad.
                                  • FarthestGiant
                                    • Nov 2015
                                    • US
                                    #37
                                    This is obviously a very old thread, but were you ever able to get the tv working again? I'm by no means a tv repair expert, but after reading through this thread, I'm convinced that my tv has the same problem. Of course at this point, the biggest problem is probably going to be finding replacement parts. Thanks for any help
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Pm sent
                                      • Lekim36
                                        • Jun 2017
                                        Hello, newly registered on the forum. I came here expressively for the same reason as the original poster. I have the identical model (currently on the floor, it's so HEAVY!), that recently started to exhibit similar symptoms. I would really like to know if a resolution was ever found for this problem. My power supply boards are operational, unit turns on with the right side of the screen illuminated briefly, showing the logo, while the left side remains dark. The screen then fades to black. Holding a lamp to the front of the screen, I can see the outline of the OLEVIA logo. Thanks for anyone's help in advance.
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          I still have boards for this set. PM if interested.
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
