Dead Olevia 265TFHD-T11
  • dskall
    replied
    Re: Dead Olevia 265TFHD-T11
    Originally posted by Lekim36
    Hello, newly registered on the forum. I came here expressively for the same reason as the original poster. I have the identical model (currently on the floor, it's so HEAVY!), that recently started to exhibit similar symptoms. I would really like to know if a resolution was ever found for this problem. My power supply boards are operational, unit turns on with the right side of the screen illuminated briefly, showing the logo, while the left side remains dark. The screen then fades to black. Holding a lamp to the front of the screen, I can see the outline of the OLEVIA logo. Thanks for anyone's help in advance.
    Need good clear straight on pictures of back of tv with cover off and each board.
  • mmartell
    replied
    I still have boards for this set. PM if interested.
  • Lekim36
    replied
  • mmartell
    replied
    Originally posted by FarthestGiant
    This is obviously a very old thread, but were you ever able to get the tv working again? I'm by no means a tv repair expert, but after reading through this thread, I'm convinced that my tv has the same problem. Of course at this point, the biggest problem is probably going to be finding replacement parts. Thanks for any help
    Pm sent
  • FarthestGiant
    replied
  • HAHOMETP
    replied
    Yes and no. I scored the main PCB off ebay and as soon as I installed it I began to get the faint Olevia start up logo on the screen so that is out of the way. Now I need to find out which of the 6 inverters (or their respective CCFLs) is bad.
  • jmannewitz
    replied
    were you able to come to a conclusion on how to get the TV active again. I have the exact same TV with the exact same issue.
  • HAHOMETP
    replied
    Yes, I did try that. No effect.
  • Tiezane
    replied
    I see this is kind of old, but if the two PSUs are identical, did you try swapping them around, and seeing if you get the same results? I see the one PSU has an extra cable connected, the one that is supplying the ~22v, it's possible that maybe just that one portion has issues, and swapping them around may get you some extra life from the TV...
  • HAHOMETP
    replied
    Originally posted by budm
    From the pictures, it has two identical power supply modules, each module supplies the 24V to 3 inverter boards. So do you get 22.7v on the output of BOTH power supplies?
    I have finally gotten around to testing the PSU's in both idle and loaded states. I have attached the updated picture.
    Interestingly the same two orange wires that are marked 24VA on the PSU (CN2) are marked +25v on the Main PCB (J55).
  • HAHOMETP
    replied
    Yes I am aware of this capability. When I first acquired this multimeter almost 20 years ago I did play with the peak and hold feature but time and again I would inevitably return to the old analogue multimeter for short spike catching and general trend observation. A slight jerk of the analogue pointer is quicker and easier to spot than to first activate the peak and hold mode and then go look for the result. Especially when the actual value is unimportant but the general trend is.
  • retiredcaps
    replied
    Originally posted by HAHOMETP
    Wavetek 2030
    Your 2030 has a feature called peak hold which might be quick enough for this test? According to the manual
    https://cdn.badcaps-static.com/pdfs/...eee71bfdad.pdf
    Works with AC and DC current and voltage and records inputs as short as 1ms. Select measurement function and apply input to meter before activating PK.
  • HAHOMETP
    replied
    This indeed sounds plausible.
    I'll check the batteries and also will take at least a couple of multimeters along with me. Besides the trusty American made Wavetek 2030 (4 places after the decimal point) I also keep around a vintage Russian made (1958) analogue multimeter that used to belong to my dad. It's indispensable in catching short spikes of voltage which modern digital multimeters tend to overlook. Maybe it'll help me catch that elusive "nanosecond-to-black" spike of voltage if it there in the first place of course.
    replied
    It looks like master/slave setup for this 65" panel.
    replied
    And usually if one is faulty, or significantly lower the other will pull it up, causing one power supply to take the whole load. If this is the case, then that might explain the drop in output voltage -- though I'd at least expect to see a 2 seconds to black like symptom where the inverter attempted to light up. Perhaps a fault detect fires immediately. I think this is a Sharp panel, and Sharp do have inverter error outputs. I'm assuming both are in parallel. It may be that one drives the master and the other drives the slave instead. Also, verify your multimeter battery!
    replied
    Both power supplies have to be working.
  • HAHOMETP
    replied
    You both have intrigued me with this new hypotheses. What if indeed the cause of the malfunction is as silly as that one of the PSUs fails to deliver the required voltage? I'll measure the actual 24v voltage on both PSU in both the idle state and under load and report back. Thanks much for the ideas!
    replied
    The LCD panel specification may give us the pinout of the inverter boards and the T-CON board. Can you see the sticker on the LCD panel assembly?
    replied
    It can make a difference. I've had inverters that shut down at less than about 23V input. Nominal range is 23V to 26V.
  • HAHOMETP
    replied
    The TV is about 40 minutes away from me. I'll check that next time I am there. 22.7v is probably a bit on the low side but I doubt that it makes the make it or break it difference. I still do not see any voltage that could tell the inverters to fire up. I have a feeling that this trigger voltage should be present in the white 4-wire harness between the left middle inverter and the T-Con. This white harness is the only connection between the inverters and the rest of the circuit besides the red +24v power harness .
  • eccerr0r
    inverter H tree driver imbalance in an AC inverter
    by eccerr0r
    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
    11-16-2025, 12:34 PM
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
  • eccerr0r
    A modified sine wave inverter + a grid tie inverter?
    by eccerr0r
    If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
    Next thing is trying to charge the batteries using solar power, but that's another issue ...
    08-31-2023, 09:14 PM
