Dead Olevia 265TFHD-T11
  • HAHOMETP
    • Nov 2012
    • 155
    Hello, folks. I've done more than a few TVs and monitors in the past but this time around I am utterly puzzled. Perhaps somebody would chime in. I also searched the forum extensively and read all the relevant threads but couldn't find the answer.
    The patient is Olevia 265TFHD-T11. The blue power LED turns on when the TV is plugged into the AC outlet and turns off when the power button is pressed. The TV turns on fine, but the screen is completely dark. No logo. No 2 seconds to black. No faint picture on the screen under bright light. Nothing at all. I don't know its history and have no clue as to which symptoms if any had preceded its failure.
    No swollen capacitors anywhere. The Main PCB lights up like a Christmas tree and shows all the voltages listed for a good motherboard in this picture (Moderators: please let me know if I have stepped over the line by posting a link to a picture in another forum). Both PSUs are good as well, although one thing remains a mystery - more about this later.
    Since IME the flashlight test does not always produce reliable results, I first looked at the inverters/tubes. There are 36 of them (6 boards x 6 inverters). Not one had lit up my trusty home made diagnostic probe built around a neon bulb from an old power switch, a 120k ballast resistor, an empty Bic disposable pen, two #120 Singer sewing machine needles, two old Fluke test probes with wires and some heat shrink tubing. I don't believe in coincidences, much less in 36 of them in a row, so naturally I shifted the diagnostic efforts upstream.
    The 6 inverter PCBs are arranged in the following manner: 3 PCBs on each side, where 1 central PCB is bridged to 1 above and 1 below.
    In addition the left and the right central PCBs are bridged to each other with a harness comprised of 24 thin gauge all-white wires.
    In addition the left central inverter PCB (let's call it the Master Inverter PCB) also has a mystery 4-pin connector populated by identical thin gauge white wires. This small harness is connected to the T-Con PCB. No silkscreen labels on either side of this harness.
    All 6 inverter PCBs receive stable 24v (23.7v to be exact) via 10-pin harnesses (5 BLK and 5 RED wires in each) from the PSUs.
    There is no voltage ever present on either of the 24 pins of the all-white harness in either OFF or ON state.
    There is no voltage ever present on either of the 4 pins of the all-white mystery harness in either OFF or ON state.
    After turning ON one of the green LEDs (D202) on the Main PCB lights up with a 2 second delay relative to the other LEDs on this board and as soon as it does +4.2v (Pin PSON on the PSU) appear on the Brown wire between the Main PCB and the PSU. However this +4.2v signal (or any voltage other than +23.7v for that matter) is nowhere to be found on either of the 6 inverter PCBs. Since the only connection between the inverters and the rest of the TV is the Mystery 4-pin all white connector, that goes from the Master Inverter PCB to the T-Con PCB, I'd hazard a guess that the Main PCB sends the control signal to turn on the inverters (and receives the feedback "LAMP IS GOOD" from each of them) via the T-Con PCB. Am I correct in this assumption? If yes, how can I troubleshoot this further? Both boards are rather expensive to replace, and on top of that the Main PCB seems to be out of stock in the whole of the USA.
    Since this TV set is huge and heavy I have to work in situ in a poorly lit room. I don't like to use flash on PCBs as it would provide more glare than useful information and I can't take pictures under natural light - it is just too dark in there. Moderators: do you feel it would be appropriate for me to use existing pictures of the very same boards from other posters floating around this forum?
    Thanks in advance for any information!
    Re: Dead Olevia 265TFHD-T11
    Do each of your inverter boards only have 24V in from the main board? No control signals like BLON? Some T-con boards have synchronisation signals which keep the inverter in step with the T-con. The idea is to limit apparent flicker and improve apparent motion response by blinking the backlight between frames.
    • HAHOMETP
      • Nov 2012
      • 155
      Thanks for the reply, tom66. Yes, that is correct. Each of my inverter boards only have 24V in from the PSUs.
      You have reinforced my suspicion that T-Con is somehow involved in turning the inverters on. I read about this before, just never encountered this design in real life.
      Also, yet another mystery lies in the PSUs. All pins in all connectors produce voltages consistent with their silksreen labeling except for the following 3 in the attached picture:
      VLAMP (feedback from the CCFLs?)
      VBL (voltage to the inverters?)
      VBRI (brightness control?)
      They show no voltage whatsoever regardless whether the TV is ON or OFF.
      This TV has two identical PSUs. One has wires connecting the above pins to the CN2 on the Main PCB:
      Pin 10 => YEL - VBRI
      Pin 11 => BLU - VBL
      Pin 12 => WHT - VLAMP
      The second one does not. Neither PSU shows any voltage on either of these three pins regardless whether the TV is ON or OFF. Swapping the PSUs did not change a thing.
      What mystifies me further still is that this picture of a good motherboard also shows that these three pins do not carry any voltage. So why were they put there with such descriptive silkscreen labels in the first place if they do not have any function?
        Can we see some pictures of your boards?
        Using external pictures is OK, but we prefer to see your own, because there can be minor changes that make a big difference, and sometimes there can be obvious failures that we can spot, but that you would not necessarily have noticed.
        • HAHOMETP
          • Nov 2012
          • 155
          I have attached a .pdf file with a picture of my Main PCB with commentaries but like I said, the quality is horrible.
            OK, the layout makes more sense to me. Sharp made the panel in this TV. They are quite the leader in massive LCD tech. Anyway, can we have a picture of the T-con? I'm thinking that there may be a fault there.
            As to why the diagram of a good motherboard does not show voltages on those pins, perhaps it was in standby at the time?
            • HAHOMETP
              • Nov 2012
              • 155
              OK, I will shoot a T-Con picture after the long weekend (it's the Memorial Day weekend here in the States). The TV is at my friend's house. I'll grab the wife's DSLR and crank up the ISO as much as I can - perhaps I'll be able to produce a better picture.
              If the good PCB on another forum were in Stanby mode, then why there's +4.2v present on the PSON pin in the PSU? I have attached a better picture of the PSU with my commentaries.
              Oh, and thank you for bearing with me so far tom66. It's way past midnight in the UK and I am hoping that I am not the reason why you're still up this late.
                I am a student; there is no "bed time" in between the golden ages of 18 to 22.
                Can you show me a picture of where the power connectors actually go out to the inverter as well? I am thinking that those lines there are a relic for smaller screen sizes where the control signals are routed through the PSU to the inverter to reduce wiring clutter. Does this TV use one power supply, or multiple? Older Olevia 65" had two power supplies in them.
                • HAHOMETP
                  • Nov 2012
                  • 155
                  Oh yeah, I vividly remember how in university years I managed to go on for months without getting a good night sleep. Still, I really appreciate you doing this for me.
                  Yes indeed this TV set has two identical PSUs. I have attached a file showing both.
                    Can you show a detailed look around the 24V connectors going to the inverter? Is there any place for inverters with 24V and VBRI/VBL/VLAMP etc., but it is not used?
                    • HAHOMETP
                      • Nov 2012
                      • 155
                      I'll try to take a few pictures Tuesday. Also the more I think about it the more I suspect the Main PCB to be the culprit. Weather.com predicts a nice partly cloudy day with 25°C for Tuesday in Philadelphia. I'll remove the Main PCB (and the T-Con PCB for a good measure), take them outside and shoot a few high resolution pictures.
                      Have a great weekend, tom66! Thanks for your help and best of luck to you in your studies. See you here in a couple of days.
                      P.S. BTW, is there a statue of limitation of some sort on editing one's own posts? I amended the MainPCB.pdf file and wanted to replace the one a few posts above but the system no longer allows me to do so. I am attaching this amended file to this message. Just didn't want to multiply entities thus creating unnecessary clutter.
                        I have almost finished my first year, just a week left. Nice and sunny in Leeds at present.
                        The limit on editing is 90 minutes after posting.
                        • HAHOMETP
                          • Nov 2012
                          • 155
                          Been to London many times but never ventured further North than Stratford-upon-Avon (to see Much Ado About Nothing) in THE place to see it. Whenever I went to the UK the weather always was dry and sunny believe it or not.
                            I for one am enjoying the annual 3 days of sunny weather.
                            • HAHOMETP
                              • Nov 2012
                              • 155
                              So per information provided by LBH in the adjacent Olevia thread the lack of any voltage on the three mystery wires Pin 10 (YEL/VBRI), Pin 11 (BLU/VBL) and Pin 12 (WHT/VLAMP) appears to be normal.
                              OTOH per information provided by mcross in yet another adjacent Olevia thread Pin 11 (BLU/VBL) shows 2.3v. His is a different TV, so it might be some other pin number on his main board, but his power supply is identical to mine.
                              Now I am completely lost.
                              • HAHOMETP
                                • Nov 2012
                                • 155
                                I took some pictures. Please see the attached file.
                                  It would appear the inverters do not use those control signals and they may well go through the T-con board.
                                    Can we see the pictures of the whole back side of the TV? I would like to see how the two connectors with white wires on the inverter board are connected to, and any labeling on those two connectors.
                                    Also good clear pictures of the inverter boards.
                                    • HAHOMETP
                                      • Nov 2012
                                      • 155
                                      Please see the attached files.
                                        22.7V is low for a 24V line. It may be enough to keep the inverters off. If you disconnect the inverters, does the 22.7V rise closer to 24V?
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
