no picture on my samsung 50 inch plasma
Re: no picture on my samsung 50 inch plasma
So, you have low Ve on X-main?
Do you have low -Vsc too?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ve is a little low... but not a big deal, it's usually got approx +/-20V tolerance on these panels.Last edited by tom66; 08-17-2013, 07:43 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The X-main waveform looks better than the Y-main.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok tom I retested but I did 2 things which I will mske 2 separate posts
1st I put back in the original xmain and xbuffer to see if the wave pattern changed
To me it pretty much looks the same
But the Ve us a little bit higher but not much
Ve: 73.4vAttached Filesif you find these attachements useful please consider making a small donation to the site
Were the both at the same V/div?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can you try dropping the intensity and changing the focus to make the trace sharper? I can see most of both sustain waveforms so it should be working, not sure why it is not.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have the same problem to and know nothing about tvs. Caps are not visibly bad. It's a 51" samsung plasma. Mine does everything you guys have been talking about except the dark room. It does not illuminate. At first there's a fuzzy red flash at the top of the screen then nothing besides a little LED light on the bad flashing. I need helpComment
It's probably best to start your own thread, including the model number.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... - Loading...
