Philips HDTV 42PFL7422D/37 - I hear the relays activate every 20-30 seconds. TV off but still connected to AC power. Pushing "on/off" button does nothing. No picture, no sound. If I unplug AC then plug back in, blue LED on front comes on for a few seconds, then goes out. I removed back cover, hoping to see a few bloated caps (I read so much about), no such luck. I still think it's a bad cap, maybe two. Anyone have any ideas on how I can confirm this, test the caps in situ, or find the actual issue? Attached is a borrowed image of the of PC boards in my unit.
Philips HDTV 42PFL7422D/37 Bad Cap? Help
Tags: None
Re: Philips HDTV 42PFL7422D/37 Bad Cap? Help
Well that picture is no use what so ever we need good clear pictures of your boards - clear enough to read the writing on them.
Do you have a multimeter and soldering iron.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
What is the resistance reading on resistor 3318 next to the gray rectangular cap?
What is your chassis number on the model number sticker on the back of the TV?
The picture you post is the EXACT match to your TV? It is better to show your board since you may have bad component that you may not see or notice them on your board.Last edited by budm; 04-05-2013, 06:36 PM.Never stop learning
That picture is a picture from the service manual. It would be nice to see YOUR tv boards. They may be different from this layout alltogether. It may have something simple that we can see that needs replaced. Either way, it sounds like a hot side cap problem.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
https://www.badcaps.net/forum/showpo...1&postcount=50
If people can't be bothered to take a clear focused picture, I hit close window.--- begin sig file ---
--- end sig file ---Comment
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... -
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
by CornitoHello Team,
New issue on LCD panel where I need to find out the cause and the potential solution.
This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
I've checked voltages, no issue found comparing right and left side of the panel driver.
VHG VGL CKV... are the sames on... - Loading...
