Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
  • Boatguy
    • Sep 2015
    Re: Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
    I don't know who this would help but here goes. I have two of these displays. One failed about 6 months ago. It would power on (blue light), wait for an input for 5 secs (green light) then shut down (two flashes of red light.)
    I unplugged it and replaced it with another unit. I left it sit on the floor next to the desk, unplugged for about 6 months. Today I plugged it in and it worked. Perfect I thought, I let it run for 30 mins and all is well. Until I powered it down and unplugged it to move it to another computer. Well, that did it. Same problem all over again.
    I know nothing about electronics, but it is almost like something gets powered and doesn't reset when unpowered. If I leave it sit for 6 months enough power drains that it resets and works again.
    I will likely toss it in the trash unless there is some cheap and easy fix. These were cheap pickups at boxing day a few years back.
    regards,
    John
    • mmartell
      • Oct 2013
      • 3189
      If you've read any of this thread you'll see that getting the eeprom replaced will more than likely fix it.
      • Boatguy
        • Sep 2015
        I read the entire thread. Even the digression which was way over my head. I ordered kit with the eprom and some other bits from EBay. Even bought the local expert repair tech a beer in advance for some soldering services. All in I should be about 30 bucks if it works.
        Thanks everyone for your help.
        • OneMeanDragon
          • Sep 2015
          • canada
          #344
          Besides eBay anyone know if there is any local electronic hobbie stores that would carry this eeprom in Ontario.
          I've gone as far as to rip the video board out to search for bad welds but found none then came across this message board the other day.
          • mmartell
            • Oct 2013
            • 3189
            Reprogram the one you have if you haven't tried already.
            • OneMeanDragon
              • Sep 2015
              • canada
              #346
              Have to find a reprogrammer yet, unless I can build one lol
              • mmartell
                • Oct 2013
                • 3189
                Failed again after MAYBE thirty power cycles. Will order a new ic and try again.
                • mmartell
                  • Oct 2013
                  • 3189
                  Reprogrammed another MX25L6406E from Digikey and set is again working.
                  Would not auto-detect the correct ic had to choose it manually. Then when I opened the .bin I had an error about it being too long and the rest would be ignored blah blah. Don't recall that error the first time ? However when it is read the saved file matches the .bin. Go figure.
                  • notsogentle
                    • 33
                    • canada
                    #349
                    I had two red flash of death also. I lifted pin 3 as shown in photos and TV has been working since.
                    I get a blank screen for 1 second every once in a while.
                    I get RFOD sometime powering on, but disconnecting AC for a minute and it starts up again.
                    I've ordered a new chip, since I know this fix can't possibly be permanent, but I'm happy I can use my TV until it arrives.
                    cheers
                    • Sorgens
                      • Mar 2016
                      Sorry for necroing. As some others in this thread, this is my first attempt at electronics. I know enough to go by, but not enough to answer my own question.
                      I already figured out how to program the eeprom, and got rid of the old one. I am ready to put the new flashed eeprom on the pcb. However, I am wondering about what I have read of the Write Protection (Pin 3).
                      Is it safe to lift that pin to avoid having the eeprom getting corrupted? Do I need to turn on the TV once, set it up with my settings, then turn off and lift pin 3?
                      Or should I just let it be until it fails again?
                      • mmartell
                        • Oct 2013
                        • 3189
                        Your procedure sounds good however of those who have replaced the eeprom (including myself) instead of just reprogramming the old one I'm unaware of any that have failed again. So I would just reinstall it and move on.
                        • Sorgens
                          • Mar 2016
                          Good, thanks!
                          Yes, I have it set up and running. The last time I used this monitor was ~4 years ago, March 2012. I am finally able to use it again.
                          I bought a new eeprom and replaced it. I also bought a cheap laptop cooling pad, removed the fans and set them up on the back right on top of the circuit board.
                          So if no one else who has done this has complained about the eeprom failing again, I am extremely happy. I still have 4 more eeproms in case I even need to replace this one.
                          Thanks!
                          • yonosoychevere
                            • Nov 2017
                            • venezuela
                            #353
                            Originally posted by rostomchik
                            Yes i did it!!! i have repeared my playstation 3d display!
                            so you need :
                            1.new chip MX25L6408E
                            2.programmer:EN25T80
                            3.SOP8 to DIP8 Adapter addapter
                            4.software ch341a
                            5.bin file:U4 25L6406E.bin
                            i flashed the new chip, then placed it om main board, insted of the old chip.
                            then powered on and it run my 3d display!!!! it works!!yes!! good work...
                            thanks to the BIN file supplier zhaojun297
                            so good luck!!
                            I have the same issue at this very moment, but as a hardware i achieved the CH341a to program the MX25L6406E. can i have possitive results with this or i need only the EN25T80 to make it work good?
                            • davy2002a
                              • Mar 2016
                              • 6
                              • canada
                              #354
                              Situation: I completely lifted/torn a pad and it's trace for resistor R21, which leads to pin 7 (HOLD#)
                              Since then attempts have failed to yield decent results, first time I ran a trace using copper wire to that resistor it would boot fine and run for a solid ~45mins then power down with the standard red flashing, now -- in my attempt to rectify the situation by adding more strands of wire/etc the resistor came right off and is now completely lost, would anyone be able to tell me precisely what the resistors value is so I may order another one? At present the system will not boot at all, black screen (no LED backlight or anything) and the usual red blink of death, I have attempted several different resistors with obviously no success.
                              • angelstak
                                • Feb 2019
                                • mexico
                                #355
                                Hello everyone I hope you still have an answer in the forum
                                I have changed epprom and regulators everything well
                                TV turns on but lasts 1 hour or 10 minutes
                                I have seen that if I put heat gun components
                                These 2 components are causing it to turn off at the min
                                Serie original mp3399ef
                                Serie en internet mp3399ef-lf
                                https://ibb.co/gyqmQBn
                                • wegosan
                                  • Jun 2019
                                  • BRASIL
                                  #356
                                  which voltage regulator did you use: 1117 - 3.3v, or 1117 - 5v?: eek:
                                  • betikt
                                    • Jun 2016
                                    • 21
                                    • hocm
                                    #357
                                    so good luck!!
                                    • rob3rt87
                                      • Jun 2022
                                      • dsfjhsfjgxfg
                                      #358
                                      Sorry for digging up. I have a ch341A pro programmer and a MX25L6406E chip. The problem is that the program says that the bios file is too large. Any of you have had this problem?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        I did.
                                        • rob3rt87
                                          • Jun 2022
                                          • dsfjhsfjgxfg
                                          #360
                                          In my case, a message appears that they are not matched. What to do? Could it be the fault of the chip. Is it the fault of bad software? I was using version 1.17.
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • protonusr22
                                            Sony 49XH9505 four flash of death
                                            by protonusr22
                                            I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
                                            The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
                                            Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
                                            Many thanks in advance,
                                            02-07-2024, 08:10 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
