Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
  • R_J
    • 9516
    Re: Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
    The software is in one of the posts in this thread.
    • as1
      • Apr 2014
      • 25
      • Argentina
      #242
      Hi MiguelUK. Muchas gracias por mostrar tu excelente trabajo. Te queria consultar si podes probar de grabar el chip que sacaste de la TV. Quiero saber si lo que se daña es el software o el chip. Muchas gracias
      • draziw
        • Aug 2012
        Originally posted by tom66
        I could see that working fine. Only concern will be if TV wants to continuously or occasionally write to memory, it might get stuck in a wait-loop.
        Would the wait loop effect the TV, if so in what way. By switching the switch to "on" will it do its thing and then you can turn it back to "off"??
          Wait loop might leave it "locking up" when you change a setting - but only one way to find out and that is to try it.
          • as1
            • Apr 2014
            • 25
            • Argentina
            #245
            Hi All, my 3d display 7400 has a MX25L6406E, with a SIX E at the end. What is the difference between the 6E and the 8E? Thx
            • R_J
              • 9516
              as1... That information is clasified but you could try Google...
              At a quick glance the 6406 comes in more packages
              http://www.macronix.com/en-us/Produc...tNo=MX25L6408E
              http://www.macronix.com/en-us/Produc...tNo=MX25L6406E
              • R_J
                • 9516
                I finally received my programer and socket, I programed the 7400 chip and will try it later to see if it works.
                Just a note about the EN25T80 programer and the CH341A software, the software shows the IC with pin 5 where the zif handle is and that is opposite from the programer which has pin 1 where the zif handle is. (The programer board is marked correctly)
                • as1
                  • Apr 2014
                  • 25
                  • Argentina
                  #248
                  Hi R_J
                  Thx you for your response. I will be more specific for people like you.
                  ¿Why if the main mother came with a 6E some people chosen to use a 8E? ¿Is there any evidence that make the 8E more stable?
                  Thx in advance.
                  • andreizze
                    • May 2014
                    • brazil
                    #249
                    Do you have it? I need one of them, and will be on Georgia nextweek.
                    I'm looking for a solution too.
                    Originally posted by rostomchik
                    i still have more 4 new chips programmed, but i cant sell it on ebay ,
                    as i live in georgia , i did it at my intrest , because i have 2 such displays and one of them broke.
                    now both are in working condition.
                    if someone has questions, i will be glad to help with it ...
                    good luck!
                    my psn is rostomchik2 , add if you like BBC2
                    • R_J
                      • 9516
                      I programed the MX25L6406E chip for the 7400 board, installed it and it worked just fine. Thanks for the .Bin
                      • rostomchik
                        • Dec 2013
                        • 11
                        • georgia
                        #251
                        ok . i have the chip . if you need it, i will help . but my country is georgia , its not in usa
                        contact me by email, my mail is rostomchik@gmail.com
                        • rostomchik
                          • Dec 2013
                          • 11
                          • georgia
                          #252
                          good job!
                          • BullRiderBill
                            • May 2014
                            • 3
                            I have the 6408 chips, not the 6406; I was shipped the wrong ones. Anybody have any idea whether the 640*8* can be made to work? I haven't been able to, but this is the first time I've tried to do this sort of thing. The software I am using to program the chip is CH341A. The "detect" button seems to work, although it lists things like Mfg as "other" or "unknown". The "Blank" function does in fact say that it is blank.
                            Past that, there seem to be problems. First, when I try to open the BIN file a popup says, "File length, beyond range of will be ignored." I can't get CH341A to write to the chip either. It trys to work for a while and then a popup says, "Write operations timeout failed!" I have tried the autoprogam button and the "program" button.
                            • R_J
                              • 9516
                              What eeprom programer are you using? you can just ignore the file length error, I did and it programed fine. Make sure the chip is in the correct way.
                              • BullRiderBill
                                • May 2014
                                • 3
                                This is the programmer I am using. I purchased it on ebay; it was one that was recommended on this thread. I have tried with the chip rotated in each direction.
                                • R_J
                                  • 9516
                                  It needs to be placed in the other half of the socket with pin one where the zif handle is.
                                  go by the [25xx] labeled on the pc board
                                  Where you have the chip now is in the wrong part of the zif socket
                                  Your socketed chip needs to be in this position (see picture) note pin one near lever.
                                  • BullRiderBill
                                    • May 2014
                                    • 3
                                    It seems the version of CH341A I downloaded doesn't list my chip as supported. I tried the options for the 6406 and the 6408(D?), but my chip is the 6408E, I believe. The version I have is 1.1 or 1.17. Could someone please provide me with a link to a newer CH341A that would support my chip? I've tried searching google, but all I can find are sites that lead me to some questionable download pages.
                                    • R_J
                                      • 9516
                                      Here is ver 1.17, its what I used. Make sure Type is: 25 spi Flash, Manu: MXIC, Name MX25L6406E, and chip in socket correctly, when Programer is inserted and no chip installed, lower right should say Device State: connected
                                      • as1
                                        • Apr 2014
                                        • 25
                                        • Argentina
                                        #259
                                        Hi, it works for me also!!!! I used the eeprom MX25L6406E and I bought this programmer http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
                                        Thx!!!!!!!!!11
                                        • as1
                                          • Apr 2014
                                          • 25
                                          • Argentina
                                          #260
                                          Hi, I have used this drivers and software: http://www.adrive.com/public/t8k2tD/...programmer.rar
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • protonusr22
                                            Sony 49XH9505 four flash of death
                                            by protonusr22
                                            I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
                                            The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
                                            Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
                                            Many thanks in advance,
                                            02-07-2024, 08:10 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
