Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
  • kornwood
    • Jun 2011
    • 93
    #61
    Re: Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
    Both of Mine has the white dot looks like white out
    BUt found the blackcat tried using a nice clip but still
    Get not supported had that issue before wirh a sb5101u
    And had to solder to the chip ill try again in a bit
    • arunningpir8
      • Jun 2013
      • 32
      tom66 is correct. An EEPROM is used for config settings and other flag based parameters usually. This is due to the fact that EEPROMs are usually slow speed and are meant to grab a couple bytes here and there, not to read tons of start-time code to boot the TV up. However everyone is correct in stating that a corrupt EEPROM could prevent the TV from completing it's turn on. For example, the configuration for "Turning the TV on when receiving an HDMI signal" is most likely stored in the EEPROM. If the EEPROM was corrupt, when you went to turn the TV on it would look to see what that setting was last set at, not find it, and essentially "crash".
      All speculation of course. I hope I get some time here to tear my warranty replaced one apart and check it out for you guys. Work is killing me the last couple days.
      • richpart
        • May 2012
        • 42
        The monitor I have belongs to a very long time friend. I will likely (not charge) him for diagnosing it because he does a lot of things to help me out as well. My goal is to determine why it does what it does, pay attention to what goes on in other sets and connect the dots. So far, I see a correlation between this device and what is transpiring in the Vizio sets. The only way I was able to determine what happened in the Vizio sets is to swap eeproms with known working ones off similar models. The result was a tv that came on and as mentioned before, might have had an inverted picture because the eeprom wasn't an exact match but, it did show me where the problem existed. Boards are expensive, I get really tired of shelling out good money for something I'm capable of resolving. It especially ticks me off when the company that built it; hides the truth.
        • kornwood
          • Jun 2011
          • 93
          #64
          So removed chip and still not recognized made sure blackcat
          Still works read a identical chip from a vizio so apears
          The chip is dead will test 2nd 3t tv tomorrow if this is the case we will need a working bin to flash to a new chip I have several donor chips to test if any one gets a working sets bin thanks
          • kornwood
            • Jun 2011
            • 93
            #65
            Well im abiut to set up and try to read the second tv I plugged I the first one
            With the spi chip removed and it has the same original issue
            • richpart
              • May 2012
              • 42
              I too, tried to see the reaction of the set without the eeprom and it does the exact same symptoms so there is no doubt really, that we are looking at replacing eeproms on these. Just need someone to take the initiative to burn and sell em. If someone decides to do so, please pm me with information to purchase. Thank You!
              • kornwood
                • Jun 2011
                • 93
                #67
                my blackcat is supposed to be compatible but using the latest flashcat software i still get unsupported everytime i connect it
                i know my programmer works i ordered some blank chips to see if i can access them maybe these chips are internaly dead
                • tedjar
                  • Dec 2010
                  • 51
                  Even moreso now given the results we are seeing (chips are not reading at all), it seems like this would be a great help to the effort if you could find some time to do it. It seems like everyone that has one of these sets has a broken one
                  • Himura
                    • Jun 2013
                    I just joined for this very problem, im very new to tv's was wondering if someone ever found a fix for this ? sorry to bump assuming still able to post being not closed by moderation and seems unsolved. I personally can not afford a repair service and incapable of affording a new one any help would be so gladly appreciated if anyone would like to pm or respond to this thread? Also would this be a main board issue or a power issue ? the 2 beeps i assume means regulation failor ? or i am mistaken ?
                    • smuddge
                      • Feb 2012
                      • 96
                      i have one of these also with same problem. what I have found is that I can get it to run again for a little while if i play with the power cable in the back of the monitor and get it to arc or make a clicking sound. Not sure why this works but everytime I play with the power cable and it clicks then next time i turn it on it works for a while. I am really hoping to find out what is wrong and try to fix it myself. Just wanted to ad this to the discussion in case it sheds some light on something else.
                      • kornwood
                        • Jun 2011
                        • 93
                        #71
                        Ok so I got a responce from 2 of the ebay sellers
                        One was kind enough to tell me the issue is with the eeprom chip
                        I asked for the bin he said they dont have it anymore
                        Maybe but anyway he told me what they did was buy a repaired one and copied it heres what I want to do
                        Ill put 30 $ towards getting one of my boards repaired
                        And take what ever donations I can get towards the rest
                        Then thise that helped will be the first ones to get a copy of the bin
                        marwoodjoseph@gmail.com
                        Is the paypal you can donate to and help out thanks
                        • arunningpir8
                          • Jun 2013
                          • 32
                          So it looks like it really was the EEPROM then huh. Well that's awesome news! Since I am super lazy anyone want to tell me if I can read the chip with SPI or something common? I have a couple programmers at home and if I have one I can read with I can provide a bin. It'd be nice to have a backup when/if my set fails again.
                          Someone do the hard work for me and I'll see what I can do about providing a bin :P
                            kornwood, you may want to ask the moderators first before soliciting donations for your own projects.
                            • bamboone
                              • Feb 2011
                              #74
                              I just donated $15 to your paypal account: I'd be DELIGHTED to have a replacement eeprom that make my display functional once again!
                              • elguardiandelast
                                • Jul 2013
                                • venezuela
                                #75
                                que saben porfin del tv sony ps3
                                • snehal
                                  • Jul 2013
                                  • 29
                                  • India
                                  #76
                                  Any Update from anybody ?
                                  My display died after a couple of months...
                                  Does anyone has a valid .bin file or can anybody confirm if its really an EEPROM issue ?
                                  • kornwood
                                    • Jun 2011
                                    • 93
                                    #77
                                    No one has a copy of it and yes it has been confirmed
                                    By several vendors that the firmware gets corrupted
                                    Several testers cant read the chip after the corruption
                                    • snehal
                                      • Jul 2013
                                      • 29
                                      • India
                                      #78
                                      That's very sad that nobody has a copy
                                      Will unplugging it for a couple of months will work, as it worked for few.
                                      Any suggestion what should I do next ???
                                      • xeroextre
                                        • May 2013
                                        • 13
                                        There are people on ebay that will repair your motherboard. I didn't have any luck waiting a month and getting it to work like some others did here, so I just had it repaired. Been working great ever since.
                                        • elecson
                                          • mexico
                                          #80
                                          hello, i´m from mexico and i got same problem with this led tv, this problem for me is SPI MEMORY, this memory have the firmware bad, i would like to get this firmware and install on this main board, i hope you understand my english best regards aroon68@hotmail.com
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                          • ekozeko333
                                            by ekozeko333
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            Yesterday, 02:48 AM
                                          • corrize
                                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                                            by corrize
                                            Hello, I'm stuck in troubleshooting…
                                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                            10-01-2022, 10:02 AM
                                          • protonusr22
                                            Sony 49XH9505 four flash of death
                                            by protonusr22
                                            I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
                                            The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
                                            Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
                                            Many thanks in advance,
                                            02-07-2024, 08:10 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
