Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
Re: Sony CECH-ZED1U Playstation 3D LED TV - Two Red Flash
Well then send a nice 7200 firmwareAttached Filesif you find these attachements useful please consider making a small donation to the site
Yes i did it!!! i have repeared my playstation 3d display!
so you need :
1.new chip MX25L6408E
2.programmer:EN25T80
3.SOP8 to DIP8 Adapter addapter
4.software ch341a
5.bin file:U4 25L6406E.bin
i flashed the new chip, then placed it om main board, insted of the old chip.
then powered on and it run my 3d display!!!! it works!!yes!! good work...
thanks to the BIN file supplier zhaojun297
so good luck!!Last edited by rostomchik; 02-28-2014, 06:19 AM.Comment
Nice! And thanks to the BIN file supplier zhaojun297.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
HI
can you give me check sun of chip
this programmerEN25T80 not support mx25l6406e olny mx25l6405
THANKS
so you need :
4.software ch341a
so good luck!!Comment
You should make a whole bunch and sell them on ebay so I can buy one :PYes i did it!!! i have repeared my playstation 3d display!
so you need :
4.software ch341a
here is the check sum :acfc546563670f2c836cba0ceb4275c1
this programmer EN25T80 can flash any mx25l64xx chips in this serias, no mater 05,06.07 or 08...Last edited by rostomchik; 03-06-2014, 02:02 AM.Comment
i still have more 4 new chips programmed, but i cant sell it on ebay ,
as i live in georgia , i did it at my intrest , because i have 2 such displays and one of them broke.
now both are in working condition.
if someone has questions, i will be glad to help with it ...
good luck!
my psn is rostomchik2 , add if you like BBC2Last edited by rostomchik; 03-06-2014, 02:05 AM.Comment
They are already available to buy.
http://www.shopjimmy.com/catalogsear...station+eeprom
and I trust them versus some Joe Schmoe on ebay selling one.Comment
is this all I need? Do I need to solder or there is a socket (solder free)?
http://www.ebay.com/itm/5pcs-New-MX-...item27d4063208
http://www.ebay.com/itm/24-25-series...item35c9c172f3
in addition would be great for someone willing to make a video or guide for dummies (like me)
Big TksComment
You need a SOP8 to DIP8 adapter too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
http://www.ebay.com/itm/1PC-SOIC8-SO...item3cc96afd34
like this one?Comment
yep - assuming the lead-to-lead width of the device you are programming is 0.208" (inches.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
ok, tks...then this one is for narrow for 25xx series
http://www.ebay.com/itm/SOIC8-SOP8-t...item4d06d61e1aComment
How about this one
http://www.ebay.com/itm/New-CH341A-U...item258a4d15ed
http://www.ebay.com/itm/High-speed-2...item20e068d2faComment
by IhandyrepairHI guys
I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
here is the issue
I have Sony and android logo. but then 4 led red flash lights front of the tv
I have 3.3v ref. 12v reg then T con 12v when I press the power on button
but then I get black screen and 4 red flash light at the front LED
but I get 3 led flash on the LED driver board.
I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
so I tried... -
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
by protonusr22Hello,
I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
Many thanks in advance,2 Photos -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
- Loading...
