Samsung LN46B610 Tiny Horizontal Lines
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung LN46B610 Tiny Horizontal Lines
    This sounds like a bad panel to me.
    LG Plasma Mal-Discharge Correction Service
    • hmendez86
      • Jun 2015
      • 344
      • united states
      i have fix tvs with this problem. i did this job on a 55 samsung led. the problem exist in the t-con were the ribbon goes the black strip that locks the ribbon with time and heats get bend not to see at the naked eyes, but true and freaky. first check the bad side of t-con by disconnecting one and were the clear image is the other ribbon is the bad side. what you need to do is add bit of Scotch tape in the ribbon like a center meter of tape folded and covering the pins of the ribbon.. the tape needs to be thin not to thick tape it would messed the black clip. thin is will be better... you going to see if there's change or not, if not move it to left or right or decrease the width of the center meter tape.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        I'm very interested in what your saying here,as I have several tv's with this problem.
        Could you explain in more detail (perhaps with pictures) what your exactly doing? KInda in the dark on the "covering the pins of the ribbon",you mean put the tape on the contact side of the ribbon? or on the other side to improve contact?
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • hmendez86
          • Jun 2015
          • 344
          • united states
          ill post pic of other TV Samsung that am working on un46d600 it has lines on top of screen i already fix it. i haven't taken picture tomorrow i do post some and how to cut tape an aline it to the ribbon
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            Yes,please do !
            • Jeff Pepin
              • Jun 2014
              • 103
              • CANADA
              #26
              UPDATE : THIS TV HAVE NO SIDE TABS
              Finding leaking cap on the top pcb that join panel to tcon , orthe tape fix would work aswell
              • dadablaze
                • Nov 2011
                #27
                any update on this, as I have the same problem on an AOU panel. Changed several TCON still same issue
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #28
                  Hi , this is not a sure solution, only my guess, locate a series o diodes o diode packs on the panel distribution boards , then remove them one at a time until you find the culprit, if found , replace with a proper tvs diode rated at about 35v..
                    • 12330
                    • U.S.
                    #29
                    Panel issue, could be component/s on panel driver board/s, could also be a bad tab bond, solved same exact line issue on an old 2010 tv not long ago with a shim over the bad/loose tab bond, if picture clears up after putting a little pressure on the tab bonds, then a shim should do the trick if that is the issue.
                    • jaco2d
                      • Oct 2022
                      • 7
                      • scotland
                      #30
                      Hi im new to the forum and this is my first post....i know this is a old thread but noticed recet replys, i have simular problem with a Sharp 50 inch tv which i am trying to repair, my issue is slightly different as when i tur the tv on its fine for about 2 hours then the lines appear. What do you mean when you said use a shim over the bad tab bond?
                        • 12330
                        • U.S.
                        #31
                        this could be the problem, try a little pressure on the tab/s see if it clears up, if it does theres your problem: https://www.youtube.com/watch?v=purk_SyiT44
                          • 12330
                          • U.S.
                          #32
                          do it after the 2 hours while the problem is active.
                            • 12330
                            • U.S.
                            #33
                            if a little pressure on the tabs has no effect, then try the taping method they mention above, if no joy, then might be a bad component on a panel driver board.
                            • noipi
                              samsung Oled 65 Horizontal Lines and Flicker
                              by noipi
                              I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                              10-14-2025, 02:11 AM
                            • Ihandyrepair
                              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                              by Ihandyrepair
                              Hi guys
                              I just started fixing 4k TV few months ago. so I am still learning a lot
                              I got this tv from friend complaint is ghosting or horizontal lines on image.
                              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                              then it started to show the ghosting white image.
                              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                              it has 3 thin small boards at the bottom of the...
                              12-05-2022, 04:18 PM
                            • Rubenlily
                              Samsung QE50Q67TAU - horizontal lines
                              by Rubenlily
                              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                              I'm no expert but I've done the tape...
                              08-16-2023, 01:12 PM
                            • x_orange90_x
                              Samsung UN46C8000XFXZA vertical bars/horizontal lines
                              by x_orange90_x
                              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                              09-04-2023, 12:09 PM
                            • arctor
                              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                              by arctor
                              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                              04-26-2025, 05:22 AM
