Element FLX-3210 no power
+ More Options
Posts
  • mopar4u
    • Mar 2013
    • 20
    Re: Element FLX-3210 no power
    Originally posted by martyparish
    bk_on and bl_on are the same thing. Often they are labeled differently by different manufacturers. That pin is what turns the backlights (BL) to turn on. The main board waits for the command to turn the TV on and if all is well, it sends the signal to BL_ON.
    A nice closeup picture of the white connector would be great. Close enough that we can read the labels.
    I believe I found what your referring to. I put one of my DMM leads on this pin, where do I put the other lead? I can't test it until I get new capacitors.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by mopar4u
      pulled the two 10uf 450v capacitors. One of them I pulled the lead out while trying to remove it from the board. The other I test and I'm getting .140nF.
      0.140nF is bad.
      Pulled one end of D10 diode out, with the positive lead near the heat sink I get open, with the negative lead near the heat sink I get .452 VDC
      That diode is good.
      --- begin sig file ---
      --- end sig file ---
        Another case of bad cap looks normal.
        • mopar4u
          • Mar 2013
          • 20
          i hope your right
          • mopar4u
            • Mar 2013
            • 20
            UPDATE: I put new caps in, now the white light turns on but no picture or startup "element" screen. The flashing red light on the power supply doesn't flash anymore. Progress is being made but not completely fixed yet. What next?
              Checked everything is connected properly?
              • selldoor
                Slow Learner
                • 7870
                #27
                test the voltages on the connectors. Meter on vDC20 or autorange. Black pin on a ground screw test each pin and report voltages against pin number a legend.
                eg
                Pin1 12v 11.59
                You can do this test in various steps all of which give clues.
                First with just the power supply plugged into the mains
                Second with main board connected.
                Third Main board connected and just as you press the on button. ( Just need to check "Pson" "B/L" ) for changes.
                • mopar4u
                  • Mar 2013
                  • 20
                  I'm questioning myself as well. I took a picture, there is a connector in the lower left next the red led light, I can't find a cable for it that goes there.
                  eg
                  Pin1 12v 11.59
                  Thanks, stay tuned for results.
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    I notice the board is not screwed down - some sets need to be to work correctly or you can provide a ground connection.
                    • mopar4u
                      • Mar 2013
                      • 20
                      thanks for the input, put all the screws in, no change.
                      • mopar4u
                        • Mar 2013
                        • 20
                        eg
                        Pin1 12v 11.59
                        Not 100% sure on exactly what your looking for, I started by doing this. Small connector in the below photo and large connector in the below photo I'm assuming is what your talking about. In order to turn the tv on and off both must be connected. So with both connected going left to right starting with the smaller connector I back probed the wire. n/w = no wire
                        0,n/w,4.9,n/w,n/w,3.2 .......... 24.9,0,0,0,0,11.9,n/w, 5.13,4.8
                        Not sure what to do next for testing voltages.
                        • mopar4u
                          • Mar 2013
                          • 20
                          UPDATE!! Got it working!! I removed the metal shrouds that the power supply and main board sit on, I found the cable that connects to the tconn board disconnected. Now that I think about it, the previous owner did say he snooped around in an attempt to fix it, he must have disconnected this cable. Turns out it was the two capacitors that DID NOT show signs of bulging or leaking. Thanks for everyone's help and input. I now have my tv for the garage.
                            Glad you got it working, great job finding the disconnected LVDS cable.
                            • capkid
                              • Oct 2010
                              • 1339
                              I've fixed a similar power supply in a Polaroid TV. I had to replace 10 HEC caps that were not bulging but had high ESR. You may have others you haven't discovered yet, so it might not be a bad idea to replace all the lower voltage caps to prevent a future catastrophic failure.
                              LG Plasma Mal-Discharge Correction Service
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • ipatch
                                troubleshooting microsoft surface pro 4 no power no led charge light
                                by ipatch
                                hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                10-05-2023, 11:59 AM
                              • russpall
                                LG 39ln540v - red light flashes twice, no power to LED driver?
                                by russpall
                                Hi there,
                                I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                08-27-2024, 01:07 PM
                                Laptop computer that went completely dead no boot no power light no hard drive light
                                by sam_sam_sam
                                See pictures for type of laptop computer
                                I checked switching power supply brick 19.2 volts multi meter only
                                No booting without switching power supply connected
                                Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                                What the heck is going on here...
                                04-04-2025, 04:58 AM
                              • gamartinelli
                                Asus VG248QE won't power on / purple light
                                by gamartinelli
                                I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
                                09-29-2022, 04:15 PM
