Bush LCD37TV016HD
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: Bush LCD37TV016HD
    nothing on the multimeter and yes it does work as tested another item.
      What does "nothing" mean? 0.000?
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
          OK, so now we are getting somewhere. Please remove the power board and take clear photos of the top and bottom sides.
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            In the last pic there seems to be a bit of diy soldering (re1) postition it is
              Pictures are fuzzy -- hard to see.
              Have you checked the fuse on PSU?
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #27
                Like a plug type fuse if so there is not one.
                  There will be one on the board somewhere. It is a legal requirement.
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    #29
                    MLT198H Is the pcb,ive even googled and cant see one on there pics.
                      There's definitely a fuse on there. Look for "AH 250VAC".
                      • LEEDASH
                        • Dec 2012
                        • 481
                        • Bedfordshire
                        #31
                        T6.3ah 250vac ?
                          Possibly. Probably. Check the terminals on the bottom for continuity.
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            #33
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              #34
                              so have i got to test this in which voltage ? with the set on ?
                              • kevinm34232
                                • May 2012
                                • 1884
                                That fuse may be on the back cover where the power cord gets plugged in like the Polaroids..
                                • LEEDASH
                                  • Dec 2012
                                  • 481
                                  • Bedfordshire
                                  #36
                                  yes i have noticed a fuse clear one ? next to where the power lead goes in to.
                                    No, set OFF, test continuity.
                                    • LEEDASH
                                      • Dec 2012
                                      • 481
                                      • Bedfordshire
                                      #38
                                      so tom,can you explain more of a dummies way as you know im thick
                                        Meter on 200 ohms, across the fuse, report what reading you get, and refrain from using "no reading".
                                        • LEEDASH
                                          • Dec 2012
                                          • 481
                                          • Bedfordshire
                                          #40
                                          right just testing this clear fuse which has on it 6.3al 250v,is 00.4
                                          • jdawg99
                                            Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                                            by jdawg99
                                            Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                                            Any advice welcome. Thanks in advance....
                                            09-18-2022, 05:30 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                            ESR meter came to the rescue again today with a PLC I/O card fault
                                            by sam_sam_sam
                                            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                            12-18-2023, 08:17 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
