Sanyo LCD TV DP26649
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #41
    Re: Sanyo LCD TV DP26649
    What is the number given on those two mosfets attached to the heatsink?
    It looks like the DLA001A can be replaced by L6598D if it comes down to it.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      A repair kit from Shopjimmy for no 12V /24V includes IC601, Q601, Q602, R619, R622 (both 0 ohm from Shopjimmy but both 10 ohms looking at the picture you posted. So I would check all these components.
      • Shock2cure
        Test Subject
        • Jul 2018
        • 140
        Originally posted by dick_barton
        what is the number given on those two mosfets attached to the heatsink?
        It looks like the dla001a can be replaced by l6598d if it comes down to it.
        mosfets = Q601 & Q602
        16n25c
        "Our technologies have surpassed our humanity" ~Einstein
        • Shock2cure
          Test Subject
          • Jul 2018
          • 140
          I checked those R619 & R622 earlier, they measure 10Ω exactly, i dont know how to check mosFets w/ a Ω meter other than to look for dead shorts/opens
          and it's outta my league on how to test a 16 pin IC
          Jimmy's "shop" has always been a bit too steep for my bank account, I can get the whole board used for 28$...
          I was just trying to repair this at component level, I'm not a board jockey fan, lol...to me, that's cheating...lolz
          DB, you've been awesome here, put yourself in for a raise here at BadCaps...lmao
          I truly do appreciate all the help here, wish i could buy ya a pint or 2
          I still got 3 more TV's to look at (I hate calling these TV's anymore)
          To me, they are Monitors with a TV tuner built in
          ...like "cellphones", I call 'em pocket computers w/ built-in phone,....
          or "Gov't tracking devices"
          • Shock2cure
            Test Subject
            • Jul 2018
            • 140
            was rooting around in my many salvage bins, I found a L6598D from another sanyo PS board, I may put it in there for S's & G's to see if anything changes there, I'll update here when I do... thanks again DB!!!
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #46
              Turn the power off to the set. To test the mosfets put you meter into diode mode --!<!-- and check between the Drain and Source pins and then reverse the leads. One way should be around 0.4 and reversing the leads should be no reading OL. This checks the diode across the mosfet.
              It wouldn't hurt to change the IC if you have one.
              • Shock2cure
                Test Subject
                • Jul 2018
                • 140
                Will do bud, Today was a good day, I learned something
                Much thanks again DB!!!
                  Did you check fusible resistor R632? It is under the big heatsink so you will have to test it on the bottom side of the board instead.
                  • Shock2cure
                    Test Subject
                    • Jul 2018
                    • 140
                    nope, not yet, set this aside to work on a customers 47" Philip's, I'm on it after this cup of joe ...hhhhmmmm, hidden you say
                    Thanks budm
                    • Shock2cure
                      Test Subject
                      • Jul 2018
                      • 140
                      R632 measures good
                      thanks again
                      • Shock2cure
                        Test Subject
                        • Jul 2018
                        • 140
                        Hey DB, & anybody else who cares, I got this puppy fired up today, but don't ask me what component failed, lol, I replaced that 16pin IC601 w/the subbed one (L6598D) & the 2 mosfets Q601 & Q602 as well, Boom!, got my 12v & 24v & 384v PFC back!!!, went thru 3 fuses in the process, but don't tell anybody about that one..D'ohhh
                        Thanks again, I would have never gotten anywhere without the assistance here
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          Glad you got there in the end.
                          • Shock2cure
                            Test Subject
                            • Jul 2018
                            • 140
                            just got my camera/phone back, here's a pic to show I'm not shucking & Jiving....lolz
                            • cj_reha
                              Mystery 80s Sanyo cap - perhaps polymer?
                              by cj_reha
                              Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                              01-06-2023, 09:24 AM
                            • toddw65
                              Sanyo DP5834 - Gray Screen
                              by toddw65
                              Hey All,
                              I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                              Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                              Thanks,...
                              10-31-2024, 10:37 AM
                            • hugocarmo
                              Sanyo VHR-D4710G VCR no sound.
                              by hugocarmo
                              Hi again guys.
                              Today I have a problem with this Sanyo VCR.
                              I bought it online, It worked sometimes.
                              I recap the Power supply and it started working fine.
                              Image is perfect and all digital effects too.
                              All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                              I have no sound on playback, on tuner, or aux in.
                              On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                              On one of the sound processing...
                              01-23-2024, 12:58 PM
                            • m4a2t0t
                              50's Sanyo monitor
                              by m4a2t0t
                              What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
                              06-16-2025, 07:04 PM
                            • stormanimal83
                              somebody familiar with hasboard repairs? BM1397AD interchangeable with Bm1397AG ? S17+ and T17+
                              by stormanimal83
                              i got myself a complete Antminer T17+ with 3 dead hasboards for a very good price.... for parts i bought S17PRO boards.... i replaced all missing resistors and changed some asics because they were bad... but wihout a tester... i used the miner instead and changed firmware to awesome miner firmware for better and faster diagnoses via miner log and lower fan speed...
                              for my understanding and what i read on the internet these asics should be interchangeable in one chain but in my case i´m getting no more communication to none of the asics on all 3 boards. 2 of the boards weren´t in...
                              04-13-2025, 04:26 AM
