What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
50's Sanyo monitor
BTW, the "(K)" may mean 10% tolerance.PeteS in CA
****************************Comment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
by keepreadHi there!
Someone gave me their old monitor, it's Dell S2715ht.
The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs... -
by 13mh13The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
https://i.postimg.cc/kGrR6BpZ/image.jpg
I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
I have not tested/replaced those alum. SMD electro PCB caps.
Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
All the thru hole electros I removed / replaced on this CDP (and most...-
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
- Loading...
