panasonic TX-P42X20B flashing red
    Re: panasonic TX-P42X20B flashing red
    Can you located the 9V, 5V and 3.3V points on PSU, and check them with and without A board connected?
    • craig417
      • Feb 2013
      • 21
      • scotland
      Hi new here so hello all.
      I have one of these tv's that was blinking 10 times. I managed to get an A board from a 37" and put that in. Managed to get the picture and sound working again, only problem now is the top band of the picture is copied to the bottom.
      Data in the tv says it is 37" model I have tried to change it to a 42" in the service settings but can not keep it to stay changed.
      Looking to see if I can get the data from a 42" to load onto my A board. Read the service manual and this is what is needed when changing to a new A board.
      Any help would be greatly appreciated.
        The 37" is 1024x720
        The 42" is 1024x768
        There is your problem, it may not be possible to change it though.
        • karlpowell
          badcaps.net
          • Feb 2013
          • 104
          • uk
          OK ...i will have a go tomorrow , I have digital meter but have never done it before and may not have a clue where to look for these test points ..... Ill let you known tomorrow with all other boards not connected.
            Any chance the 42X2 is close enough?
            http://www.tgohome.com/ServiceManual...&Search=Submit
            Voltages on page 51. Look for for "To P-Board (P6)".
            Pin 1: 15V
            Pin 2: 15V
            Pin 3: 15V
            Pin 4: 0V
            Pin 5: 0V
            Pin 6: 0V
            Pin 7: 15V
            Pin 8: 15V
            Pin 9: 15V
            Pin 10: 0V
            Pin 11: 0V
            That's obviously only the 15V rail... there is a 9V and 3.3V rail on there... I am not certain if it is close enough and will look up exact SM if I can.
            • karlpowell
              badcaps.net
              • Feb 2013
              • 104
              • uk
              #26
              http://img841.*************/img841/4052/vout.png
              this is a picture of what voltages i got from each one , I noticed that P6 would slowly drain the 15v after a 15 seconds or so from each pin.
              there is nothing at all on P35 which i assume is the 9v rail , If i remove all connectors from the P board except AC in , i dont hear the relay click over and i get 0v on all points tested above.
              • karlpowell
                badcaps.net
                • Feb 2013
                • 104
                • uk
                #27
                if you need anymore pics let me know
                  Unfortunately, I cannot find a service manual for this set, but I will ask a friend if he can get it. This may take time.
                  • awyatt2
                    • Feb 2012
                    • 407
                    • america
                    #29
                    tom, i have it by chassis number but it is for the 50 inch version. if you think it will help i will try and email it to you. dewey
                      Yes that would help very much. It is likely to be close enough.
                      • karlpowell
                        badcaps.net
                        • Feb 2013
                        • 104
                        • uk
                        #31
                        thank you awyatt2, Tom thank you for your help .
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #32
                          Any chance you could upload the service manual or a link to it
                          • awyatt2
                            • Feb 2012
                            • 407
                            • america
                            #33
                            sorry i was at work and just got home. i am emailing it to tom now.
                            • karlpowell
                              badcaps.net
                              • Feb 2013
                              • 104
                              • uk
                              #34
                              If its a power supply fault, it looks like i can source 1 for around 30 euros , this might be the chassis number ... mc106h30u13 .
                              http://www.ksp-electronics.com/downl...file=404767423
                              http://www.ksp-electronics.com/downl...file=404767424
                                Here is what awyatt2 sent me.
                                http://www.tgohome.com/ServiceManual...ic_TH-M50HD18_[SM].pdf
                                • karlpowell
                                  badcaps.net
                                  • Feb 2013
                                  • 104
                                  • uk
                                  #36
                                  link doesn't work tom, what do you think about the voltages from the P board ... do you think this could be the fault ?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #37
                                    ignore wrong thread sorry
                                      Ah, did it again... Try this one:
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        #39
                                        thanks a lot Tom , I can see that the voltages from the P board are not correct ...ive not got a clue where to start
                                          Check without the A board connected.
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
