panasonic TX-P42X20B flashing red
    Re: panasonic TX-P42X20B flashing red
    It is not always possible to do so from the normal system menus.
    • sienoki
      sienoki
      • Jan 2012
      • 314
      #82
      Karl there is same set 4 sale on leeds gumtree with smashed screen at 50quid fella
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        • uk
        #83
        BIG BIG THANK YOU to Sienoki AND TOM, I picked up the TV from leads and replaced the A board , and the set is now working , this all so means I have some spares for this set available
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by karlpowell
          BIG BIG THANK YOU to Sienoki , I picked up the TV from leads and replaced the A board , and the set is not working , this all so means I have some spares for thsi set available
          Did you mean NOW working? Otherwise you seem awfully pleased it's still not going
          • karlpowell
            badcaps.net
            • Feb 2013
            • 104
            • uk
            #85
            Originally posted by craig417
            Any one know what might need changed on the a board to repair it or where to get the data from a 42" a board to change it on my 37" a board.
            Or even how to change the resolution to enable full picture.
            you more than welcome to this faulty A board I have if you can find any use for it .
            • karlpowell
              badcaps.net
              • Feb 2013
              • 104
              • uk
              #86
              sorry typo set is now 100% functioning
              • tw2005
                • Oct 2011
                • 6458
                Woo Hoo. love the animation
                  Stick the other boards on eBay so others can use them. You should be able to get back at least your 50 quid.
                  • karlpowell
                    badcaps.net
                    • Feb 2013
                    • 104
                    • uk
                    #89
                    will do thanks again for your help.
                    • craig417
                      • Feb 2013
                      • 21
                      • scotland
                      #90
                      Glad you got your tv going again Karl, was wondering if you could copy data from your A board now by SD card as in service manual 6.5 and post on here so I could copy to mine see if it fixes/changes my settings to a 42".
                      Would be greatful if you could thanks in advance.
                      As for your faulty A board, probably same fault as my original one, and would not know where to start a repair on it. But thanks for the offer of it.
                      • tw2005
                        • Oct 2011
                        • 6458
                        I don't know if this will work but have you gone into service menu and drilled down to Panel type in the option field. On my 2009 series it shows 42HD, OK. Toggle with Vol - , shows a second option 50HD , NG.
                        Maybe it's selectable in there??
                        • craig417
                          • Feb 2013
                          • 21
                          • scotland
                          #92
                          My boards from a 37" and I've been on that bit and mine said 42NG and tried selecting it but just goes back to 37"display on switching on again. Dnt know if there was anything else needing done for it to stay that way. Been through all ye service manual and says to check other things if NG displayed. Hope to get data from board if someone could copy it to SD card and post it on here so i can try it to fix mine.
                          • tw2005
                            • Oct 2011
                            • 6458
                            That's a shame, hope the data copy works if you get it, total size of my data copy files from my 50 was 112kb. hopefully someone can help you out.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Out of curiosity, when you toggled to the 42, it was red. Did you hit ok, it changes to black and then restart the tv? I'm not brave enough to fool around testing mine and changing to 50 just in case I lose the picture or the menu goes off screen otherwise I'd have a go.
                              • craig417
                                • Feb 2013
                                • 21
                                • scotland
                                #95
                                Sure I tried that but did not stay as 42 when switched back on. Was a little while ago now trying to mind from memory. Not able to try it again just now. Even tried changing all the settings possible to what was shown in service manual but think it may be an unchangeable setting in eprom or something as to amount of pixel lines it shows on the screen (37" 720 lines 42" 768 lines). Then it just copies the top 48 lines on the bottom of the picture.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  That sucks, an option that's not an option. it'll be interesting to see if a data copy works then.
                                  • craig417
                                    • Feb 2013
                                    • 21
                                    • scotland
                                    #97
                                    Just a thought there tw2005, if you copied the data from your 50, could you post it on here and I could give it a try out of curiosity and see what happens. Should have asked you this earlier, doh. I have a copy of mine as it is so no problem going back the way if I had to. Or I know where I can get another board at the moment if I really had to go that way. But the guy got the whole TV for £35 with cracked screen and possibly a courier cost but now wants £40+£5 postage for each of the boards he took out of it, and on his listing he has it stated as working board taken from a NEW TV with a cracked screen. But the guy that sold the TV had been asked by a friend to skip it for him, so it's not from a new TV as per his listing.
                                      I've come to realise everyone selling cracked screen parts on eBay lies about testing them. :/ I've received a few dud boards that after a short argument I've got a refund and lo-and-behold a new board fixes the problem. Frustrating though.
                                      I'd guess that a 50" panel would be worse. It has 1366 columns (as opposed to 1024 rows on both 42" and 37") so enabling that may cause loss of HSYNC = scrambled picture.
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        #99
                                        Craig please PM me your email and ill get the file to you today .
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Lies, lies everywhere Tom. I think you and I have established that fact both Ebay and Stri & ship businesses. SJ is about the only one I feel is testing as much as possible and from the majority of parts they do appear to have come from brand new damaged in transit TVs. Some of the older Tvs maybe not.
                                          The NZ A board I have which I inherited was an EBAY advertised as essentially new from damaged in transit screen. A lie- go into the service menu and it had in fact clocked 3000hrs.
                                          Either the seller does not know it's logged or assumes the vast majority of buyers would not know how to find this information.
                                          Some of these newer TVs with cracked screens on Ebay it would not surprise me some creative people intentionally crack the screen to claim insurance when they find out how expensive the repair is going to be.
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
